I’m edging towards nobbys
Surprisingly poor combo with a Magic Mary up front. Basically, the Mary highlights the shortcomings of the Nic to the extreme.
but the more I think the less I think I ride in mud in the summer.
Rock Razor on the back is genuinely the most impressive tyre I’ve ridden. You expect it to be quick, you don’t expect the tenacious grip when leant over, or the fact that it seems to grip really well when climbing on a multitude of surfaces as long as it’s not muddy. Obviously, it’s not good under braking (but then it teaches you to lay off the back brake and use the front brake more, which is good technique anyway), but otherwise it’s genuinely the best rear tyre out there for a surprising range of conditions.
Also a very good rear tyre, it’s quicker rolling than you might expect (though not a quick tyre compared to a semi slick), and grips just like a Minion DHF in the corners, but has better braking traction.
