254k on my Y reg Passat 1.9tdi Mine is the 100 bhp PD engine.
FSH 1 owner / driver from new , not a taxi but a private company car.
I paid £800 for mine at 242k . I can get 60mpg from mine in the summer, its dropped to around 55mpg in the colder weather ( thats actual fill – fill as the fuel comp under reads)
Cambelt changes are early every 30k IIRC , and the suspension is known to wear . This might be a mix of OE componants and a heavy car.
Cheap tax too on mine £140pa
cats are known weak point and as the engine mounts wear the increased movement snaps the downpipe.
some leak from cabin air intake area, check carpet in passenger footwell , if its wet walk away as there are alot of expensive electrics in the footwell.
Got a set of 16″ audi ‘Trapez’ alloys on mine which look better than the crap steels it came with.
Nice blue dash, climatronic is a little wonky on mine and tends to over compensate .
No chance of any veg oil as they are extreamly high pressure injection systems.
Obliged to use 505 501 oil in oil changes which is a touch expensive
Have a look on fleabay , They do go for a surprising amount of cash , evem with moon and back milages
HTH STM
