Last couple of rides had issues with my 2014 XTs. Pulling right back to the bars and no power. Fitted new pads and did a full bleed midweek and they felt better, but in The Peaks yesterday I was back to no rear brake at all (even with trying to ‘pump it up’) and front feeling about 50%.
Checked pads today – worn from the Peaks grit but still serviceable.
Bled front again – no air in the system and feeling fine again.
Bled rear – LOADS of air bubbling through – eventually got it feeling firm again, but don’t have much confidence that it won’t go squidgy again.
Seem to remember XTs being notorious for leaky seals? Air is obviously getting in somewhere…
Can’t see any fluid leaking out either end, so how do I confirm this?
Second set of XTs I’ve had this issue with on the rear brake especially, whether I bleed them myself or get my usual mechanic to do it.
Should I persevere (when they work properly, they’re top brakes)? Switch out the levers/calipers (could be an expensive process), or cut my losses and switch brakes? Do SLX/Zee/Saint suffer the same leaky issues? Are Hope worth the cash (don’t really want to go Avid unless really necessary – too many bad stories about maintenance of them).
