Need a bit of advice…
I’m part way through my first attempt at servicing a 2014 Rockshox XC32 solo air fork (oil and seal change). I’ve got the correct seal kit and I’ve got the lowers off.
I’m following this pdf : https://www.sram.com/sites/default/files/techdocs/gen0000000004444_rev_b_sektor_recon_xc32.pdf
But it only describes how to service lower legs and the air spring, not the damper side. Should I be taking apart the damper as well, or leave it alone? The turnkey lockout still seems to work OK.
Ooo, second question – to regrease the threads and seals when reassembling all I’ve got is a tube of Decathlon own-brand red (teflon) grease. OK, or do I need something more specific??
Thanks
