I saw news http://singletrackworld.com/2013/09/lighter-wider-faster-more-wtb-deliva-kom/
430gram is crazy light. Also carbon rims from Lightcycles, but I decide stick with normal aluminium rims.
Currently I have Mavic 721 and 823 but I’d like to go lighter. I usually share wheelset between dh and enduro rigs (20mm/150mm)
Would it work with Super Comp in front and CX Ray spokes in rear? It will be brass nipples. I’m figuring that stronger spokes will help held “too light” rim longer under abuse. So CX ray might be bad idea after all and Comp 2.0 would be safe buffer.
What kind of spoke tension will it require for that kind of buffer? I did read that CX ray requires 130kg as minimum.
Weight of the wheelset would be same as Mavic Enduro wheelset. Having proprietary wheel system makes me skeptic as it would be expensive to repair in long shot.
Planned wheelset:
Tesla 20mm front / 150mm rear
DT Super Comp / Comp 2.0
DT prolock brass nipples 12mm
WTB KOM i23
I dont expect the rear wheel to hold longer as I dont mind replace rim every or each second year. I will have 823/Hadley/Comp as reserve rear wheel for burlier conditions.
Your thoughts?
