Viewing 40 posts - 1 through 40 (of 45 total)
  • Would you disconnect car battery when going on holiday ?
  • unfitgeezer
    This summer we will be away for 3 weeks touring Europe in the camper van so the Passat will be at home guarding the fort !
    Thinking I might disconnect the battery to stop battery drain and the alarm going off (not that it has) by accident.
    Would you bother ?
    scotroutes
    Battery drain – 3 weeks??
    I had a car sitting in the garden for 5 months and it started first time.
    legend
    Nope
    Suggsey
    Nope.
    dirtyrider
    just leave it ticking over, nobody nicks passats
    unfitgeezer
    Okay no battery drain then but alarm going off by accident….it happens when you least expect it and getting a call from irate neighbour is not something I want whilst on holiday 👿
    Harry_the_Spider
    Leave them with a key then.
    Turn off your phone.
    unfitgeezer
    Harry_the_Spider – Member
    I don’t like them ! and I have 2 sets of neighbours to potentially annoy ! and both work full time
    theblackmount
    Better get it up on bricks as well in case someone nicks the wheels 😉
    **** me – have you nothing more important to worry about?
    Teetosugars
    If you don’t like the neighbours, then it’s no drama If the alarm goes off then is it?
    I bet you unplug everything at night too just like Grandma. 😆
    unfitgeezer
    Yes plenty but thats why I’m asking now ! being organised !
    unfitgeezer
    bugger off !
    Harry_the_Spider
    If they are at work how will they know if the alarm is going off?
    trail_rat
    Thats some belief you have in your car……
    Must be a vw to be that confidence inspiring…
    unfitgeezer
    It might go off at night these things always happen at night, dark windy rainy nights !
    unfitgeezer
    You got it in one !
    Harry_the_Spider
    Kill your neighbours.
    captainsasquatch
    Would I? No.
    Should you? Yes. It’ll put your mind at rest and let you enjoy the holiday. just don’t tell anyone as they might come along and nick it safe in the knowledge that the alarm ain’t going to go off.
    unfitgeezer
    a bit extreme plus Id come back to a flat battery if it did go off !
    dirtyrider
    thinly veiled “I’m off touring in Europe” thread
    unfitgeezer
    captainsasquatch – Member
    Would I? No.
    thanks sensible person
    unfitgeezer
    dirtyrider – Member
    eh ?
    TrekEX8
    If the battery is uncharged for more than about two weeks, reverse electronolysis will occur in the ECU, particularly on VAG models, which will cause the stator valve in the throttle valve to display a false negative, cutting the fuel flow during start and, by implication, causing the lambda sensor to signal inaccurately due to the coanda effect.
    Personally, I’d keep it connected.
    anagallis_arvensis
    Only if you are confident the radio will work when you return. Dont alarms stop going off after a certain kength of time anyway?
    scotroutes
    When the battery goes flat?
    Cougar
    It’s faulty then, get it fixed and leave your battery alone.
    In a quarter of a century of driving, the only times I’ve had car alarms go off by accident is if it was an aftermarket Moss special fitted by a gibbon (ie, me) or if I’d left the windows open without disabling the ultrasonics inside.
    And frankly, if I was leaving my car unguarded and unmoved for three weeks, I’d want the bloody alarm to work!
    sharkbait
    Lock the car but don’t set the alarm – then it can’t go off.
    (i.e. press button on B post to disable internal sensors)
    Thank me later.
    jambalaya
    For 3 weeks no.
    molgrips
    You may want to turn the alarm off – there’ll be a button for it. However, mine’s never gone flat in that time, not with a known good battery anyway.
    stumpy01
    I wouldn’t, but then my car alarm has never accidentally gone off.
    Has yours? If not, then don’t bother.
    If it has, then you could consider it. Or get a trickle charger and keep it plugged in while you’re away.
    carlos
    Me – I wouldn’t bother, but it’s you asking so how about removing the fuse or relay to the alarm?
    Sorted
    scaredypants
    FFS drac – you even work in the health service; those iron lungs have to be on all the time 🙄
    Inbred456
    If you are worried go to Maplin and get a solar powered trickle charger and leave it in the window facing South. Cost about a tenner. Worked for me when I laid up my Mondeo for a couple of months.
    bugger off !
    Kryton57
    I’d drill a hole to let the water out – it could be full up by the time you come back. 😉
    unfitgeezer
    no water in mine…not now anyway ! and you can bugger off as well and btw you better get some rust treatment gonna need it soon with that Alfa !
    esselgruntfuttock
    & leave the handbrake off, but leave it in gear. You’ll see why if you dont.
    trail_rat
    Whys that then essle ? Its only 3 weeks, not 3 months.
    I leave my french car sitting for 6 weeks quite regularly.
    The pads dont stick to the disks,
    The alarm doesnt go off
    And it starts first turn…..
    Did leave a hyundai for 6 months once. I cam eback threw a new battery on and put it straight for an mot. It passed .
    Oh and kryton i thought you didnt do funny…. That was a goodun 😉
    fasthaggis
    I know a bloke (big John) that will sleep in your car for £75 while you are away.
    It may smell a bit,but he will make sure it starts when you get back.
    Mail him on westealanycar@pastwatford.sco.ochaye
The topic ‘Would you disconnect car battery when going on holiday ?’ is closed to new replies.
