First of all Andrew, apologies for consistantly missing your e-mail.
dreednya is correct – at the moment IS headtubes are not supported – we did make some prototypes but there is a much greater allowable tolerance between frames with IS headtubes due to the drop-in bearing fitment – there could be upto .1mm difference between manufacturers. Because of this it is difficult to make a headset that we can guarrantee will fit different frames.
If it is any ‘standar fit’ headset we have you covered in one way or another now.
Just to explain the sometimes poor response etc – we are a small business which struggles to keep ahead at the best of times – i went on holiday 3 weeks ago and managed to bring a pretty nasty bug back which as done the rounds here – that with being quite busy has put us on the back-foot.
In no way would we ignore e-mails deliberately, we just need to catch up so please dont be offended.
Please try and email again if it is not an IS headset or if you have any querys – sent to the normal address with the title FAO Rick and i will see you get a reply in a timely manner.
Thanks, Rick@Works
