Anyway, are they easy to fit as intended and what’s the quality of manufacture like on them?
1. Search me…
2. Quality is good imo anyway. I found fitting it pretty straightforward, there are markers on the cups, I lined them up centrally using a metal rule and some thread around the seatpost for visual reference and a headset press to fit them.
It’s not very difficult, you just need to be methodical. Also, according to Saar Gelvin, there’s a reasonable margin for misalignment, like about 2mm or something from memory, so even if they’re very slightly out, it shouldn’t be the end of the world.
I’ve fitted two now and I’m by no means an ace spanner monkey, so it can’t be very difficult. On the Pace I used the rivets on the head badge as an additional reference point. Neither the Saar or Works headsets have creaked, come loose or worn prematurely so far and, I think I’m correct in saying, use readily available standard sealed bearings.
