- This topic has 58 replies, 24 voices, and was last updated 9 years ago by footflaps.
Woodburning stove – cost?
TheFlyingOxFull Member
It’s going to happen now, seeing as I just pulled the old fire surround off the wall to see what was behind. Question is, what’s a reasonable price?
I’ve been to the local installers – who have a reputation for being a bit expensive – and they’ve quoted just shy of £5k. That’s to take our old crappy 90s gas fire, widen the fireplace hole, new hearth, brick out the new hole, put in a big beech mantel thing, and install 8kW stove with all the required flues, liners, plates, etc. plus our first ton of dried hardwood. It’s a stone cottage with chimneys already in place if that helps, stove by itself is ~£1200 and labour charge is £1150, 2 men over 2 days. Is £5k reasonable or do I need to be shopping around?Dales_riderFree MemberIf I told you I have just done said job for £700, minus a ton of logs, would you believe me ?
TheFlyingOxFull MemberOh, and location is NE Fife. Going rate for trades up here is £250-£300/man/day
TheFlyingOxFull MemberIf I told you I have just done said job for £700, minus a ton of logs, would you believe me ?
You fancy doing it again?
duckmanFull MemberI fitted my own stove. Liner,all prep to fireplace and new pot for £1000.Co monitor would suggest I did a goot job. Biggest expense was a second hand stove. You might want to ask for a breakdown of where the money is going; for example most sweeps round here will install the flue for £300…would have been £300 for 45 mins work in my case. Even going posh, if you are contemplating it,that sounds a bit sore. What stove do you want,liner is £20 a metre for 916,the rest of the stuff is all bitty; pot £45,rebate plate etc all cheap as well.How much for your hearth and can a local bricky/plasterer open it all up cheaper?
jimjamFree MemberCheck your chimney. If it’s in good condition you may not need a flue liner and vermiculite etc. Could save a pretty penny.
It doesn’t help you but I had a new 20kw boiler stove fitted, 300ltr tank, all associated plumbing and considerable structural work to chimney done for a good bit less than £5k. Maybe £3k all in.
duckmanFull MemberYou are an hour from me, what exactly is it you want done to the fireplace? (I’m a plasterer)
nedrapierFull MemberI’ve had a quote for much the same: remove hearth and brick surround, widen inc lintel, strip rest of chimney breast and replaster and paint, install slate hearthstones, sweep chimney, install flue and all necessary gubbins, commission, inspect, small pickup of logs. £2.3K + whatever 4-5KW stove we fancy.
rugbydickFull MemberHave you tried the Stove Shop on the Newport-Leuchars road? They’re supposed to be pretty decent.
geoffjFull MemberOx – I have the contact details for a good installer in your area if you are interested. He did mine in Perthshire. He’s good and reasonably priced.
Dales_riderFree MemberThe Flying Ox – Member
Nope 🙂 sat here with it fired up nice and cosy and warm.
You need to read up and DIY
TheFlyingOxFull MemberHave you tried the Stove Shop on the Newport-Leuchars road? They’re supposed to be pretty decent.
Not yet, can’t get hold of them. It was the one at Guardbridge I’ve been to.
Yes please. Email in profile.
ahwilesFree Memberfirstly, 8kw is a fairly serious stove, that might just be too much. My parents put in a massive stove, because they liked it, and now Dad spends most of his life cleaning baked-on tar from the glass as they have to run it with the vents closed up to keep the room temp below 10,000C. They’d have been better off with a 3kw.
Anyway, there’s a few days work to rip out, sort, and prepare a fireplace for a stove. Plus materials: hearth stones, etc.
liner? + fitting?
register plate?
nice stove?
it all adds up quickly. £5k? it sounds a lot, but it’s believable…
TheFlyingOxFull MemberYou are an hour from me, what exactly is it you want done to the fireplace? (I’m a plasterer)
I want this:
turning into this:
martinhutchFull MemberFor 8kw I imagine they would also be fitting some additional ventilation somewhere to comply with regs?
Sorry, does that include the stove? If so, I would say that it’s not too far away from reasonable for a signed-off job. You could probably save some money by getting different trades to come in and do different bits.
Dales_riderFree MemberThis recent thread explains a lot
I knocked all the plaster and pointing out myself Cost = £0
Local Brickie Pointed it up for £190
I sept the chimney Cost = £0
I put the hearth in Materials cost = £50
Register plate I designed and had made at local sheet metal works cost = £40
New stove [slight damage to enamel] £250 reduced from £600.
Flue, right angle joint fire cement Cost = £80TheFlyingOxFull MemberFox YGM
Nothing yet… 😕
I’m quite liking the idea of just getting the SDS drill out and attacking the wall. We’re having the whole living room redecorated after a water leak before Christmas, so it’s going to be chaos for a bit anyway.
tinribzFree MemberHad a one a couple of months ago for just short of 4k after vat. Remove existing gas fire, alterations, flue, new stove (about 1k). Can send you the detailed quote if you want.
Just do it, wife will have a duster wont she ?
TheFlyingOxFull Memberthe popolis_uk address?
That’s the one. Still nothin though…
cajsparkyFree MemberYou may find this website helpful http://www.stovefittersmanual.co.uk/
I opened up a modern fireplace and lined myself then had a stovefitter supply the stove and drop flue and connect for £1k including Hetas Cert.
Opted for a Granite hearth which cost £250.northshoreniallFull MemberNewcastle here, just had 5kw stove, flu liner and pot top, remove gas fire, sort out hearth ( we supplied granite tiles – add £150 for slate one) open out firplace and fireboard around sides and skim front of chimney breast all done 2 1/2 days £2200 Like above watch size, inlaws had monster fitted couple years ago and ended up needing get removed as were badly advised.
Edit – that includes them supplying stoveTheFlyingOxFull MemberSo the consensus is that £5k is a bit steep then. I thought as much.
I’ll give the wall a damned good looking at tonight to see what I’m working with, then post back here with pics.As for 8kW, the living room isn’t huge at 13ft x 17ft x 7.5ft, but the house is so very cold and draughty. We plan to open up the stoop through to the kitchen (which effectively doubles the size of the initial space to be heated) and use it to heat upstairs as well via the double winder staircase off the living room. It’s a very oddly laid out house, if that all sounds a bit weird.
mrmoofoFull MemberQuote here in Brighton are as follows
Stove – Morso
Take out rubbish gas fire and make good
Flue liner
Fit stoveAround 2.5k providing we don’t need scaffolding ( which we probably will)
But it seems to be a nightmare – lots of fly by nights, all the competition dissing everyone else. There is a no liner vs liner discussion. I was told I had to have one legally – and now I am told if my chimney is good enough, I won’t …
But I have no idea of the parameters that govern this!spooky_b329Full MemberI think I paid about 1.5k for a £500 stove, granite hearth, open up fireplace and make good, and a chimney pot check and cowl fitted. I asked for a liner but he was positive it wasn’t needed, probably would have been £800 for one of those (only a bungalow) so fairly short if needed.
cajsparkyFree MemberAs mrmoofo states there does seem to be a lot of conflicting advice out there regarding liners!
I chose to assume that the stoves are designed to work with a liner and that is where their efficiency is graded so I fitted a liner.
Would be interesting to know if people are managing to heat more than their living area with a large stove as the OP is hoping to do.trail_ratFree MemberI went from 4.5 to 7kw in my gaff
4.5 would heat the room and be working hard to do it., 7 heats the hall and the upstairs/bedroom while needing less fills and holds flue temperature more evenly.
mrmoofoFull MemberDue to the lack of consistent advice, we may well go the route of a jet master fire … It will only pump out 3 kw but that should heat the front room as a secondary source of heating (it’s bleeding cold when it is cold outside).
Anything more than 5 Kw will fry a house – unless it is being used as primary source / really big open space. BTW the room I am trying to heat is 4.5 x 4 metres with high victorian ceilings ….footflapsFull MemberWe have a 5kW in an open plan Victorian Terraced House (3 bed) and it heats the whole downstairs nicely – when it’s really cold outside it takes a while, but once up to temp it pretty much replaces CH entirely.
djflexureFull MemberWe have a 5kw Charnwood and it provides plenty of heat for large lounge (6 x 4m ) with doors open to other spaces. Seems to run cooler with seasoned oak compared to reconstituted wood blocks.
5K seems like too much – get a few quotes, meet a few fitters.brickwizardFree MemberHey duckman wher do you get the 916 liners from at £20 per m??
TheFlyingOxFull MemberRight, so a bit of exploratory demolition has me slightly confused. Despite the house being built of sandstone, the internal wall in which the fireplace sits looks to be entirely brick and with no lintel in sight. The current fireplace cavity only goes back about 12″ as well. This wall is a gable end which used to separate 2 buildings (1 x two storey, 1 x single storey, now knocked through into one house) and is a good 3 feet thick. Would a house built in the early 1800s normally have stone exterior walls and brick walls inside, or am I going to have to remove the bricks to see what’s behind?
Also, the position of the chimney flue – which happily looks to have a very good condition 9″ clay liner inside – seems to be off-centre and not very deep-set at all, which would make our plans to widen the fireplace a bit trickier.Regardless, I’ll be taking the plasterboard off the whole wall at the weekend and we’ll see where we stand then.
That’s the main reason we’re after a stove. Gas bills in the winter are close to £200/month just to maintain 19°C. There’s a place down the road delivers chopped, kiln-dried hardwood for £73/ton. It’s a no-brainer, and if I end up doing most of it myself it’ll have paid for itself in a couple of years.
brFree MemberThat’s the main reason we’re after a stove. Gas bills in the winter are close to £200/month just to maintain 19°C. There’s a place down the road delivers chopped, kiln-dried hardwood for £73/ton. It’s a no-brainer, and if I end up doing most of it myself it’ll have paid for itself in a couple of years.
I’d spend the money insulating the house myself and then take a look at your boiler and rads.
FWIW We’ve a 7.5kw stove in a room about 6m x 8m and +2 storeys height, it keeps it warm (we’ve no CH, but just an Aga in the other room).
TheFlyingOxFull MemberJust had a new condensing boiler fitted, all windows are double-glazed and loft spaces are insulated already. That’s about as far as we can go though, cos it’s all solid stone walls – no cavities to insulate. It’s just an old draughty house, and I reckon we’d spend a lot more than our £5k stove quote to prevent any more heat loss.
cajsparkyFree MemberIt sounds to me as if you would be best to call a brickie in and get some advice and even quote for opening up your fireplace to suit your spec of stove.
I would personally leave a minimum of work to the stove fitters i.e. fit flue closure and stove as they will probably only be subbing the building work out anyway.I am sure this will bring your costs down!jimjamFree Membercajsparky
Would be interesting to know if people are managing to heat more than their living area with a large stove as the OP is hoping to do.Currently heating the entire house with the boiler stove. Three bed semi with an attic conversion, all rooms nice and toasty. Stove is 16kw to the radiators, 4 to the living room. Worked out pretty much perfectly. A smallish fire will see the living room at about 22 – 23 degrees, the adjacent kitchen about 22. Master bedroom above the living room holds the tank so is always toasty. Bedrooms about 20 degrees including attic conversion.
It seems kind of wasteful to generate all that heat and not do anything with it, especially when the cost of the install wasn’t much more than a standard stove.
cajsparkyFree Memberjimjam great stuff! How much fuel do you get through as a matter of interest? You got me thinking….
jimjamFree MemberIt varies quite a bit, some months I’ll try and keep a really tight eye on it and run it very economically, other times I’m frivolous and burn through fuel like it’s going out of fashion. Currently (after xmas) I am in economical mode.
That’s about 5 25kg bags of phurnacite a month at £8 per bag and maybe half a basket of sticks/logs a day. Currently working through scrap wood, and various bits of deadfall/windfall from nearby forest. So cost is zero.
In the past 12 months I’ve bought logs two or three times. I can’t remember, I think three. Local guy delivers 1.5 ton builders bags for £40. The problem is I tend to take it for granted when I buy it in and use it pretty quickly but that amount will last at least a month, two if used carefully.
The topic ‘Woodburning stove – cost?’ is closed to new replies.
