Northwind I used to hate the rear Crudcatcher’s – they were always coming off after every bigger bump. Until I realised there is a small lip on the other side of the guard, that needs to be pushed in (with a screwdriver) under a recess in a mounting bracket… Rock solid since then!
Nah I got that (though it wore after a while so I ended up plastic welding the 2 parts together) It was the 1-bolt thing, couldn’t get it tight enough to work because it stripped the plastic first and it only had an allen key hole on one side. Ended up machining the “bolt” down and putting a bolt right through the middle but it just seemed like a total design disaster.
The older crudcatcher with the 3 bolts was ace, wish you could still buy those. Or the old mounting and the new blade design
