MarkBrewer
Yep it was that bit, did it 3 times and even ended up going down past the house to the road to see if I could find where I was meant to go, so do you turn off somewhere before the rooty drop because I didn’t see anything obvious.
Yup, if you get to the Droll (halfway between a drop and roll) on The Empire, then you’ve now gone too far, and you should have turned left about 25 yards before it. However, the Droll is fun, so we usually do it all the way, then just loop back up the main sandy double track and do it again, this time turning off left.
Back in the day, you could go straight across the fire road, and into a super fast series of drops, which was ace!
