My Lexmar Prospect 2800 wireless all in one jobby has always been a pain from out of the box, but after about a day of trying I managed to get it set up – this was just over a year ago.
Now, every now and then, I’ll go to print and my laptop tells me it can’t communicate. My router network map shows it as disconnected, everything I go into shows it as offline, or turned off, apart from the Lexmark Printer application, which shows it as ready????
However when I go to the printer, it recognises the network, shows a wireless connection and good signal strength. I’ve tried a reset with the push-button method, but the printer and router don’t seem to connect, although this has randomly worked before.
I’ve tried switching off and on again, before anyone suggests.
I don’t know where to go on my PC to find and manually make a connection to the printer and I’ll be buggered if I’m bringing it in to the same room every time to plug in an ethernet and go through the wholoe set-up process every time.
If I was to add the printer manually, the ‘add printer’ process asks me for the address of the printer, but I’m not the most computer literate and haven’t got a clue what it might be.
Please help, or should I boot it out of the window and buy a better one?
