Wireless analogue T...
[Closed] Wireless analogue TV signal sender?
[#1144412]
Analogue TV aerial socket downstairs. Want to get it upstairs without running cables. Is there a wireless solution for an analogue TV signal?
So something that plugs into a regular aerial socket downstairs and then magics it to a box upstairs which I then plug the other telly into?
Anyone?
Ta
Posted : 19/12/2009 5:53 pm
 ton
no.
Posted : 19/12/2009 6:33 pm
One of these?
http://maplin.co.uk/Module.aspx?ModuleNo=44469
Posted : 19/12/2009 6:40 pm
 ton
that is to send a av signal to a tv.
something like a sky box, or a dvd player.
i am pretty sure there is not a device that plugs into a aerial outlet plate and sends a picture wireless to a tv.
Posted : 19/12/2009 6:42 pm
 5lab
an aerial?
Posted : 19/12/2009 6:48 pm
But I could use one of those digitial senders with a DVDR box I assume. The DVDR box has a tuner built in to record from the analogue signal. Presumably I could just punt that into the sender?
Aerial > DVDr box > Sender
Receiver > TV
and then use the DVDR remote to change channels or play a DVD?
Why would that not work?
Posted : 19/12/2009 7:51 pm
 jwt
That should work,(given the way you asked the question Ton was right) you need an analouge tuner somewhere in the circuit before you send a wireless signal upstairs ,with the advantage that you could watch DVD's upstairs as well if you chose a DVDR.
Posted : 19/12/2009 9:03 pm
 ton
geoffj
that will work mate, but that is not what you asked....was it.
i recommend a televes av sender...
and i can sell you on trade...
ring me on monday morning
01132633500 ask for tony..
Posted : 19/12/2009 9:07 pm
Sorry folks I wasn't trying to be clever - my later post was more of a thinking out loud after realising that I wasn't going to get a pure analogue solution.
All for the bluddy mother in law as well 😆
Posted : 19/12/2009 9:52 pm
