Will my Hope Pro 2&...
[Closed] Will my Hope Pro 2's rear hub take a 142*12mm rear axle??
[#2263379]
i have just bought a Trek Fuel EX8 2011 to replace my old Stumpy FSR. Can i get an adapter for the rear hub to enable me to swap wheels/axle to 142*12 at some stage?
i know i can use them as is by swapping skewers, just thinking forwards...
Posted : 08/12/2010 12:22 am
Says on the website you can get a new axle with spacers. At the bottom of this page[url= http://www.hopetech.com/page.aspx?itemID=SPG71 ]Hope pro2[/url]
Posted : 08/12/2010 1:21 am
Course it'll need to be a full thickness spindle, or the hub will snap.
Posted : 08/12/2010 1:59 am
Yes, I've just done the same adaption for a Cube Stereo frame. You need to buy the Hope conversion kit @ £20-£25ish. This rear axle standard is also called X-12, your Pro2 hub will definitly adapt to X-12 (142mmX12mm)
Posted : 08/12/2010 2:08 am
