It’s not unusual for thieves to target ‘nice, quiet’ areas, they’re less likely to be noticed, and there’s likely to be better pickings, higher value cars, etc.
Steal it myself one day park up around the corner and only come clean after she’s panicked for long enough?
I’d do this!!
The idea’s good in principle, but the repercussions could be decidedly unpleasant, and leaving keys just inside the front door is almost as bad as leaving them in the door, thieves can and will fish for them through the letterbox.
I’d just drop them into a bowl or put them on a hook in the kitchen, then when she suddenly needs them and can’t find them, just quietly point out they’re where they should always be.
In which case now is the time to be kind to each other & not turn this into a ‘thing’. Next time it happens just take the keys out & gently mention it saying that you’ve put them safely inside. It helps if you have hooks/ bowls etc where these things live – so you (both) actively notice that they are in the ‘right’ place rather than dangling in the door. Life is hard enough in the circumstances you describe – make light whilst still ensuring that your stuff stays safe.
Exactly.
