As FW said though, the address conflict isn’t a router issue. You need to resolve that first.
The router has a pool of addresses it knows it can allocate (called a ‘scope’); typically, this might be 192.168.0.2 > 192.168.0.254. If you program something with a static IP address in this range, eg you set your Sonos box or printer manually to be 192.168.0.5, the router doesn’t know this already exists and so will allocate the same address. Two devices with the same address = IP conflict.
To fix it, you first need to find it. Then, either set the static device to use DHCP (ie, to get its address from the router), or if you must manually configure the device then it needs excluding from the scope. To do this, either add the address as an exclusion, or reduce the size of the scope so that eg your scope runs 192.168.0.2 > 192.168.0.100 and then you assign manual addresses from .101 upwards.
Hope that makes sense (-:
