Why is my house so ...
[Closed] Why is my house so cold?
Didn't bother but probably not expensive. (I have some plasterboard type stuff as a ceiling in cellar so insulation could go in here).
The link I put previously to action 21 shows one way, I've also heard of people using loft insulation held up with chicken wire, but would also work if you have a plasterboard ceiling.
Posted : 04/12/2011 8:41 pm
I did the under floorboards insulation in our dining room. It has made a fair it of difference. Took up a hatch of maybe three widths of floorboard and went down into the crawlspace (18-36") Used Space Blanket jammed between joists and stapled in place. Messy job, but I was redecorating and putting a new carpet in too. Put a higher TOG rated underlay in too, and I think that made more difference, along with completely sealing all gaps under skirting.
[url= http://www.carpet-underlay-shop.co.uk/cloud-9-cumulus-pu-carpet-underlay-11mm-19-p.asp ]http://www.carpet-underlay-shop.co.uk/cloud-9-cumulus-pu-carpet-underlay-11mm-19-p.asp[/url]
Makes even thin carpets feel lush too.
Posted : 04/12/2011 8:46 pm
Why is your house cold?
Because UK building standards and thermal performance standards are useless, on new houses and even worse on old houses.
Where to start? Buy the [url= http://www.amazon.co.uk/dp/1898130051/?tag=sustainable0f-21 ]Green building bible[/url] and join the [url= http://www.aecb.net/ ]AECB[/url]
Posted : 04/12/2011 8:53 pm
Hora - don't put a platic sheet down on the floor.
Whilst you may think your current floor is tight and sealed there will be air getting through - this is a good thing as it provides ventilation. Which you need.
Can you tell I'm a civil engineer?...
Posted : 04/12/2011 9:03 pm
All rads bled?
Posted : 04/12/2011 9:08 pm
Plastic isn't a substitute for proper insulation. You need a bit of thickness under there. That is your major leaching of heat under the floor.
Find someone with an infra red digital thermometer (or spend £20 on EBay on one). Then go around the house checking the temperatures of the walls / windows / floors etc and you'll see for yourself where the heat is going.
Posted : 04/12/2011 9:42 pm
We normally insulate suspended wooden floors with 200mm of Mineral wool (held in place with stapled 3mm ply straps)
If there is enough space, it's done from underneath. When done that way we would seal all the edges with expanding foam and cracks with frame sealant.
If we do it from above, we would remove all the boards, fill with the same insulation held in place with a wire mesh, and then replace the floor with 22mm t&g chipboard (glued and screwed) with a foam underlay underneath.
Then seal all the edges to make it air tight.
The idea that you use gaps in between tongue and groove flooring and spaces round the edge of badly fitted floors as "ventilation" is frankly rediculous.
You need to be able to control ventilation, gaps are just draughts that you can't control, and they are not recommended.
Posted : 04/12/2011 9:56 pm
Having a purge here - first Winter in new house. Extra insulation added to loft plus draught excluders on all the downstairs doors.
Downstairs bathroom is like an ice box and the ceramic tiles don't help.
Next job is sorting out reasonably heavy duty curtains as the old double-glazing is draughty.
Am determined to reduce heating costs!
Posted : 04/12/2011 9:58 pm
The downstairs of my house is feezing since i took out the wall between the living room and conservatory, brrrr.
It does look nice though 🙂
Posted : 04/12/2011 10:12 pm
I'm sure all those numbers on your heating bill will be just as lovely! 😀
Posted : 04/12/2011 10:16 pm
I must admit the heating is on higher than usual and it doesn't take the chill off the living room, and it's not even that cold or frosty yet 😕
I have a nice big blanket though
Posted : 04/12/2011 10:20 pm
While on the subject, does window insulate film make much difference? I've got a big single glazed window in my kitchen. There is no radiator in there, two external walls and roof (which i suspect has little insulation). There's no chance of getting a new window as I rent.
Posted : 04/12/2011 10:28 pm
I really have no idea why that could be... [img] http://www.smileys4me.com/getsmiley.php?show=2140 [/img]
@CaptJon, I don't know about this film of which you speak but have you thought about secondary glazing? No idea on cost or availability or quality or look or....
Posted : 04/12/2011 10:33 pm
After a winter last year spent with the heating on full blast and the house always feeling cold it's a pleasant surprise to find that our new (to us) house doesn't seem to need heating. It's 4 degrees outside and we've not needed the heating on all day and I'm normally a bit nesh.
Not really a huge difference between the two houses, both had cavity fill and 300mm loft insulation, similar ages, both semis so the difference in warmth is a bit of a mystery.
Posted : 04/12/2011 10:36 pm
Plastic film is OK, easy to fit and very cheap.
Slightly better option is a plastic sheet cut to size and attached magnetically (or with other frames)
http://www.theonestopplasticsshop.co.uk/clear-cast-acrylic-1000-3-mm-p-1395.html?osCsid=e5t7emnvqah27polrtregfgst5
Good tips on insulating under a suspended floor, we've got high ceiling cellars so I need to get on and do that.
Posted : 04/12/2011 10:37 pm
As stated - unisulated suspended timber floor.
Posted : 04/12/2011 10:42 pm
 hora
"both semis so the difference in warmth is a bit of a mystery."
Next door is identical to ours. Not as good on the combi etc but a big difference on warmth when neither is heated. Maybe previous owner had the underfloor mod etc.
Posted : 04/12/2011 10:58 pm
Orientation?
Posted : 04/12/2011 11:05 pm
Orientation +1. Probably has a nice south facing wall and heat soaked brickwork.
Thermal insulation is to reduce heat loss but also prevents heat gain, like a thermos flask.
Posted : 04/12/2011 11:27 pm
gravity-slave,
Pay particular attention to the edges of each room, expanding foam round all the edges to seal the gaps.
We put lights on in the room above and keep cellar dark to spot any gaps in the middle of the floors too. But obviously that won't work if you have carpets. Just put frame sealant anywhere that looks like it might provide an airway.
And put a plastic membrane between the insulation and any outside Walls, just in case of damp (we use the bags the insulation comes in normally)
Posted : 04/12/2011 11:34 pm
Try this web site justinsulation.com
[url= http://www.just-insulation.com/celotex_pl4000_pir_insulated_plasterboard.html ]justinsulation.com[/url]
Also have you had your heating system power flushed
if not give that a go, and also are your radiators full of rust
if so change them ASAP
Posted : 05/12/2011 6:28 am
Our front room was always cold so i replaced it with a double radiator
Posted : 05/12/2011 6:45 am
Have you considered heat distribution? In our house there's a bit of interplay between the thermostat and the TRVs. The thermostat is on the ground floor at the end of the circuit, so if you turn it up the TRVs on the other floors can close and direct more heat to the ground floor which heats that floor but also redistributes it better through the house. Something to consider, if the radiators are not all warm.
Posted : 05/12/2011 8:15 am
a bit radical 🙂
Posted : 05/12/2011 8:30 am
 hora
Shirley radiatical? 😈
Posted : 05/12/2011 10:27 am
 Gunz
I've been tackling this in our 19th Century cottage (thick walls and draughty). So far the things that have made an immediately appraciable difference for minimum outlay have been the plastic film on windows and reflective insulation behind rads (Lidl have it on offer at the moment).
Posted : 05/12/2011 10:34 am
I was thinking of this for my house.
The 2 upstairs bedrooms have very old single radiators with no convection fins, so are not heating the rooms anywhere near as effectively as a single or double convector radiator.
One of these bedrooms is 4.5 square meters with 2.5m ceilings, so I'm pretty sure an old 300mm x 1500(?)mm radiator is pretty useless for a room this size.
The living room also has an old single radiator.
Posted : 05/12/2011 12:40 pm
 hora
Re my earlier comment. I know I'll get laughed at but this is the toys/toy box that was uniformly and neatly put away and fully closed.
Wierd.
Posted : 05/12/2011 1:35 pm
Anyone looking to change radiator sizes should look at doing the calculations. A simple version is at:
[url= http://www.radcalcs.com/ ]http://www.radcalcs.com/[/url]
and
[url= http://www.theradiatorcompany.co.uk/heatoutput/ ]http://www.theradiatorcompany.co.uk/heatoutput/[/url]
There is no point in putting an oversized radiator in if it compensating for other problems like draughts or poor insulation, both of which are cheaper to fix than heating the room repeatedly.
A dehumidifier is no substitute for proper ventilation.
How would one get 'proper ventilation' in a late 1800s stone-built terrace, incidentally? (Sorry for the hijack)
Posted : 05/12/2011 1:40 pm
TooTall, not sure if we've spoken off forum before, but is there any chance you could pop me an email (in profile). Cheers.
Posted : 05/12/2011 1:42 pm
[url= http://www.retrofitforthefuture.org/ ]http://www.retrofitforthefuture.org/[/url]
That has loads of good stuff for improving the energy efficiency of your house. Some of it is a bit OTT but pick out the bits that might be of use.
Cougar - can't say as you've not said how you live in the house. Questions like 'do you dry clothes on radiators, what windows do you have, open fires, how many live there, 24 hour occupancy or not, cook a lot, shower a lot' all matter.
Don - I'll mail you later when I get home.
Posted : 05/12/2011 2:50 pm
Clothes dry in tumble-drier or cistern cupboard, not rads. Non-vented double-glazing at the back, original (I'm guessing) single-glazed wood frames at the front. Gas fire in the back room. Two people, two bedrooms, out at work during the day, cook evenings and weekends, shower's in daily usage. The heating works but is archaic.
The front of the house suffers from damp. The problem started donkeys' years ago when I wasn't using the rooms and so just left them fallow with the doors closed, and a leaky gutter hasn't helped. Assuming these are the causes then I've 'fixed' them but the house isn't really drying out.
There's what looks like a vent brick on the front which has been covered over (plastered / papered) inside, and the gas people helpfully put a "vent brick" in the back room ("regulations, mate") by removing a great big stone from the wall and leaving a force nine gale belting through it. Needless to say, that got covered over fairly quickly too.
I've been toying with getting a dehumidifier for a while, but I don't know whether that's "the solution" or just a workaround.
Posted : 05/12/2011 3:04 pm
TooTall - thanks for those links, most useful.
Hardly surprising my downstairs bathroom is freezing so will probably replace electric towel warmer with one that runs off the central heating. Am really quite cross with myself for thinking that electric would be better and have wasted money. 🙁
Posted : 05/12/2011 3:10 pm
 hora
A decent plumber should be able to add in an extra radiator for £100 tops plus the cost of the radiator in the existing radiator network' (you could supply it yourself from screwfix etc).
There will be STW'ers who will say 'no! do it yourself its easy!' however I'd prefer someone to do it who does it every day.......not muppethands..
Posted : 05/12/2011 3:15 pm
Thanks hora. Waiting on a call from my plumber cos c/h needs sorting out. Wonder if I can sell my 2 month old towel warmer on Classifieds!!
Posted : 05/12/2011 3:17 pm
 hora
That £100 would include the additional copper as well IMO.
Posted : 05/12/2011 3:18 pm
This lot came this morning, my job for the week. Lining out the utility room.
Posted : 05/12/2011 3:23 pm
joao3v16 - Member
We moved into a house in Feb that had very old radiators. They would get hot to touch, but the rooms weren't heating up; they didn't seem to convect very well.
My OH's Dad is a retired plumber so he replaced most of the radiators with new ones with convectors on them & new TRVs. The difference is substantial. The rooms heat up a lot quicker.
Only problem we have had is that we now have some pipes that are clanging for whatever reason. See my recent threads for a run down of this. Still looking into the cause.
Posted : 05/12/2011 3:55 pm
 hora
Stumpy, theres an air bladder(sp?) inside your combi boiler - is it pressurised/boiler been checked? Sounds like a pressure issue and the noise can reverberate down the pipping? (note the ?'s- i.e. guessing).
Posted : 05/12/2011 3:58 pm
If you need any advice drop me an email: nealglover@gmail.com
I do this every day and have a few short cuts etc that may be of help.
And also things to be aware of that are easy to do, but hard to fix later if you miss them out.
Posted : 05/12/2011 4:04 pm
hora - Member
Nice thought hora, but it's not a combi boiler......
We've closed the lockshields on the 2 radiators that seem to be giving us the problem, until I find the time to rip the flooring up....that'll be after Christmas now, I reckon.
Posted : 05/12/2011 4:10 pm
 hora
Final longshot (the other thing I'd think of):
1. Furring/build up within copper pipe of radiator fillings/sediment.
or
2. the pipes have nothing between each pipe to prevent movement/banging against each other when heated.
Posted : 05/12/2011 4:15 pm
After 30 Yrs in the Central heating game I am asked this question more now than ever.
The simple answer is..You dont have your heating on for long enough, or your room thermostat isn’t set high enough.
With the rising fuel costs we are now paying attention to the heating control settings we used to ignore only a few years ago.
I was recently called to a house, the owner said she is always cold. I took one look at the timeclock and saw the heating had a 1.5 hr on period in the morning and 2.5 hrs in the evening. The house was poorly insulated admittedly but, If the house takes 1 Hr to heat-up it takes the roughly the same to loose the heat, that means its unlikely to be warm enough for more than a few hrs a day in cold weather. The room thermostat probably never reaches the set-point.
BURNING £5 notes in the middle of the lounge would have been a more cost effective way.
Extreme I know but you get the idea.
If you want to be warm, 'its Gona Cost Ya'.
Posted : 05/12/2011 4:33 pm
I suspect/hope it is only 2. The system seems well looked after, so hopefully won't be furred up.
I tried securing the pipes under a section of floorboard that I removed in one of the rooms that the noise seems worse in. This made no difference and putting a hand on one of the pipes, you can feel the pipe vibrate with each bang, like someone is tapping it with a spanner further along.
Next job is to take up floor in our bedroom once Christmas is out of the way.....
Anyway - didn't mean to hijack.......
Posted : 05/12/2011 4:35 pm
Page 2 / 3
