Sorry, wrong wording! 😳
Meaning that the effort involved in pedalling is driving the cassette and lockring clockwise therefore unlikely to have it unscrew itself. 35 Nm isn’t a particularly high force so tightening it up til your gurning like a monkey shitting a pineapple isn’t going to do your freehub any good. I do mine tight, but not stupid tight so it won’t come off ever again! Without a spot of copperslip etc they can ‘spot -weld’ on over time – apparently, had this explained to me by a shop mechanic who’d been on the cytech course. It seems that when steel and aluminium come into contact with a water interface the resulting difference in electrical properties of the two materials can cause micro welds to occur, making the parts hellishly difficult to move. Alu seatposts in steel frames are the classic example.
This does assume you have an alu freehub and steel lockring of course.
EDIT : lockrings/hub bodies do also have those serrated ‘teeth’ that lock together to prevent slippage as well, so tight but not stupid tight is what i was meaning!
