Who can justify the cost of 160mm forks?
[quote]I still don’t understand why anyone would want 160mm singlecrown forks[/quote]
You’re now changing your question.
To answer the first – Me, that’s who.
To answer the second – some bikes are designed to ride correctly, or at their sweet spot, using this size fork. However, I believe axle to crown is a more important measure than mere travel.
For example, I like my forks to be supple in their initial travel, but ramp up towards the end. Ths helps maintain geometry around the bike’s sweet spot, but gives a bit in reserve if it all goes a bit wrong. If they had a long axle to crown but short travel, a bit like marzocchi of old, then I feel like the fork is out of it’s depth.
Sure, some might argue I’m using them as a skill compensation, but I couldn’t give a hoot what they think – as long as I’m happy and not hurting anyone else – who cares?
I currently run 140mm Rev’s on my 5, and 180mm Totem’s on my Quake. neither bike feels over or under forked – they just feel right for those bikes.
