which ss cog for ho...
[Closed] which ss cog for hope pro2 rear wheel
[#1920915]
due to the freehub being made of cheese i wanted a thicker based one. surly/andel are just short of 5mm , some of the gusset ones are 7mm and there is a superstar cnc one that has a 10mm base.
im presuming the surly/andel last longer but the fact the superstar is 10mm width is appealing for the pro2.
any thoughts ?
Posted : 22/08/2010 8:02 pm
 MSP
http://www.chainreactioncycles.com/Models.aspx?ModelID=17774
Thats what I am running on a hope hub.
Posted : 22/08/2010 8:19 pm
have you inspected it at all 😉
Posted : 22/08/2010 8:26 pm
 igm
Might as well chuck On-One Groove Armada into the mix - I think they might be on offer.
That said I'll be running a Surly when I build it up.
Posted : 22/08/2010 8:30 pm
Surly from Charlie for me.
Posted : 22/08/2010 8:31 pm
used surly before i just wasnt sure about the alu freehub as they get damaged easy enough from just a cassette
Posted : 22/08/2010 8:33 pm
I run the On-One and the Surly cogs on my Hope hub without any problem.
Posted : 22/08/2010 11:55 pm
another vote for gusset double six http://www.chainreactioncycles.com/Models.aspx?ModelID=17775
run it on my pro2 and its awesome, no marking after about 200 miles including some trail centres in south wales (not that that makes any difference)
Posted : 23/08/2010 12:24 am
Cheers chaps
Posted : 23/08/2010 7:59 am
Surly for me (yes, from Charlie!), admittedly haven't inspected it for a while.
Posted : 23/08/2010 8:47 am
 MSP
firestarter - Member
Yep, its on my commuter, having run it for about 6 months, 100km a week, recently moved and have a hillier route into work, so swapped the 14t for a 17t, found no marking on the cog.
Posted : 23/08/2010 8:51 am
Thanks again
Posted : 23/08/2010 9:25 am
are these "cogs" / Sprockets compatable with the DMR conversion kit or do you need gusset spacers for gusset sprockets and so forth.
I am curious as i have Pro II's that i intend to SS and have ordered a DMR kit already but was concerened about the alu freehub so have a gusset sprocket incoming also ....
Posted : 23/08/2010 10:52 pm
