Aaaaarrrrggghhhhh !
I am so close to completing my new Liteville build.
Finally my x-fusion sweeps arrived (yes I am looking forward to the trails coming alive) but when I try to mount my XO Trails using the 40 mm mount adapter supplied it all goes Pete tong. In short the calipers sit too far from the rotor and the pads barely make contact.
Without the adaptor the caliper is too close, only tightening down to the fork mounts when in the dip of the wavey edge of the rotor
I’ve been on the Sram site and identified what I believe to be the correct combo of parts. It’s a 160mm travel fork and if I read the chart correctly the this requires the 40mm adaptor. It occurs to me that the 160 referred to in the chart may mean the size of rotor which can be mounted direct without adaptor but this isn’t made clear – anyone know which it is ?
If the latter then if the fork is designed for direct mount of 180mm rotor then the 20mm adaptor is the way forward. Unfortunately the x-fusion site provides no info on this so right now it’s a guess.
In writing this I may well have answered my own question but does anyone have any first hand experience with this issue so I don’t start ordering random adaptors willy nilly.
