Which jockey wheels...
[Closed] Which jockey wheels for XT 9 speed?
[#3750150]
Can anyone please suggest a good replacement for XT 9 Speed jockey wheels?
Posted : 07/03/2012 4:33 pm
I had the same issue recently and changed mine to Tacx at my lbs. I paid £18 and I know I could've found them online cheaper like here http://www.ukbikestore.co.uk/product/25/gp4050/tacx-910-spd-shimano-jockey-wheels.html but they fitted them FOC.
I can honestly say that I haven't noticed any difference in performance compared to the originals. What I did notice was visually how worn the originals were compared to the new ones. I didn't buy into to the benefits of the ceramic bearings.
Good luck
Posted : 07/03/2012 4:59 pm
kcnc about £20 last for ages and look great if you can see them under the clag
Posted : 07/03/2012 5:05 pm
LX ones were £2.99 a piece at CRC. Nowt wrong with them. Not ceramic bushed ones like XT though.
Posted : 07/03/2012 5:11 pm
BBB from dotbike, 10x better than standard. about a tenner I think
Posted : 07/03/2012 5:12 pm
BBB here as well and they've been fine so far. I am considering some KCNC ones though as i'm wondering is the machined out areas on them means they collect less muck?
Posted : 07/03/2012 5:34 pm
 FOG
No, more. All the little holes fill up with neat plugs of mud.
Posted : 07/03/2012 5:35 pm
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=22262 ]Eyewatering![/url]
Posted : 07/03/2012 5:42 pm
OMG
Posted : 07/03/2012 5:45 pm
Just get the BBB ones from Dotbike for £10, remove a rubber seal from each bearing to fill with lovely grease. Fit and ride. For years.
Good as XTR, cheaper than XT, infinitely better than a steel bush with no seals using slurry as a lube/abrasive until you get sloppy changes from a worn guide pulley (read Deore, SLX, Hone, LX and even lesser groupos).
PaulD
Posted : 07/03/2012 6:37 pm
Another fan of bbb here, got the ceramic ones, think they were £16, lasted ages and totally problem free. Great replacement.
Posted : 07/03/2012 6:41 pm
aye just get the cheap ones.
as for lightweight alloy ones, I got a few sets of the $11 a pair sets from Toronto cycles for myself and some guys I used to ride with in Bristol and they have been great. Think they worked out at about £8 a set posted. So far I would say they clog up less than flat plastic ones. I think it's because the spokes chop up the mud a bit instead of just letting is accumulate between the plates, chain and jockey.
Posted : 07/03/2012 7:23 pm
+1 for
Posted : 07/03/2012 8:23 pm
Thanks very much!
Posted : 08/03/2012 2:59 pm
BBBs fitted. Much appreciated!
Posted : 12/03/2012 3:52 pm
Edit: nothing to see here 🙂
Posted : 12/03/2012 3:56 pm
