Up to you as long as your measurements are accurate as it's close…most stems are 40mm stack height (like Thomson) so that leaves 20mm, given you need a couple of mm gap between top of steerer and top cap that would be fine with a CB headset. Equally go with a 35mm stack height stem (like some FSA), leaves 25mm so with the gap between steerer and top cap an XL2 or similar height headset would fit.
Oh and FWIW I have an iodine C headset…fitted last autumn and it now has surface rust on it and the lower bearings don't feel that smooth.
