As per the title.... I just need a single 15mm all travel spacer for my revelations. Anyone know where I can get one? Closest I can find is a £12 spacer kit from TFTuned.....
Thanks.
Thanks.
2010?
ill sell you one. mtb_crasher @ hotmail.com for details.
ta
Not sure, 2009 probably (140mm) but I think they are all the same anyway.
don't think so part no. 11.4015.450.00 for 2010 kit only has 10mm or 20mm in but machinable to 15 if needed, will double check if compatible. Which fork??
got a 10mm you can have for nothing
Thanks for the offer - but really need a 15mm.
I'm guessing they're revs dual air 140mm, sram parts list 2010 spacer.
Rock Shox Revelation Race 2010 Dual Air 140 with Poplock .... IIRC.
Hmmmm, I put one spacer in at the weekend, it came with the fork and was 15mm. I want to add a second spacer.
That's just typical! The kit only has 10mm or 20mm! so I guess you need a 10mm and 20mm. I could machine one of the 20's down but looking at them you wouldn't have that much material left either end for the other components to butt up against so the 10 and 20mm are best option.
Mail me in profile.
Actually it's a 2009.
Oddly this parts manual LINK lists 3 variants of the revelation; 130mm 2005-2008, 140mm 2009 and 150mm 2010. But only one spacer kit; 11.4015.450.000
Mind you, I want to reduce the travel by 30mm, which the 2005-2008 manual lists as two 15mm spacers, but obviously if the 2010 10mm + 20mm kit fits it amounts to the same thing!
The joy of Sram parts lists eh! Checked a rebuild kit too and same 10, 20mm combo in there too. I've got them if you need them so just let me know if you don't have a luck elsewhere.
Use my 10mm and run 5mm more sag - as if you would in the real world notice 5mm!!
