Its not that simple, I tried it, I had a customers Frame needed re anodising under warranty, so got the frame back took it to be stripped and polished pre ano, they dipped the frame in the tank, then the problems begain, because the frame had been out in the weather it had got contamination that the eye could not see, and this made the anodising very poor, the other thing that happens is any steel or brass fitting desolve in the ano tanks so you will need to fit new bottle cage boses etc, So unless its a brand new frame thats fresh off the press its not going to turn out to be great job,
Best best is to get a good wet or powder coat paint job
