Where can I buy an ...
[Closed] Where can I buy an air tank?
 IA
[#3856426]
In the uk. This sort of thing:
I know I could fashion something out of an old coke bottle and some valves, but the above seem relatively cheap in the states etc. and I'd assume a bit less explosion-prone. Can't find one for sale in the Uk though.
For seating tubeless tyres, if it wasn't obvious...
Posted : 10/04/2012 4:40 pm
 IA
Hmm, 1st one quite pricey, bigger than the small ones I've seen I think.
2nd pick up only, not sure about an old pressure vessel, possible rust/leak issues.
3rd also big, collection only again...
I [i]did[/i] actually look in the obvious (to me) places, but maybe someone has a better idea.
Posted : 10/04/2012 4:47 pm
damn! not one of these then 🙂
http://www.bbc.co.uk/news/world-europe-11511886
Posted : 10/04/2012 4:50 pm
old fire extinguisher and go speak to the nice man at your local compressor/airtools shop
Posted : 10/04/2012 4:51 pm
Plenty at Matt savage, dunno if they are what your looking for though
http://www.mattsavage.com/acatalog/Tanks.html
Posted : 10/04/2012 4:52 pm
http://www.machinemart.co.uk/shop/categories/search/air-compressors
somewhere like this?
I've got some diving cylinders I could sell you for a decent price, collect in Leeds?
Posted : 10/04/2012 4:58 pm
 IA
I may go up market ghetto - what pressure does that hold, not sure I'd risk more than 40-50 in it before getting scared? Enough to seat a tyre?
Leeds is a bit of a mission I'm afraid.
Posted : 10/04/2012 5:00 pm
What are you intending to pressurise it with?
It'll take a while with a track pump, I'd have thought.
How about using a 5m long 1/2" hose as your reciever? You'd need a stop valve on one end with a line to your tyre valve, and your track pump connected to the other end.
Posted : 10/04/2012 5:04 pm
Not sure home much pressure ghetto will take but it does have a pressure release safety valve. I'll see how many pumps of the handle it takes to pop out and work back from there.
Posted : 10/04/2012 5:10 pm
I can't see why someone hasn't worked out a way of doing it with mains water pressure.
Posted : 10/04/2012 5:11 pm
 IA
Hose might work, but is only about 1.5 x the volume of a 29er tyre, with some rough maths.
Well, if it has a safety valve, it must be safe. Sorted 😉
Does it work well for you? Volume wise it's about 2 tyres, so should provide a good flow to seat a tyre I'd think?
Posted : 10/04/2012 5:24 pm
It's more than likely you own something suitable already. You don't really need that much pressure to seat a tyre, just lots of volume so a car tyre at about 35-40psi works perfectly.
Posted : 10/04/2012 5:29 pm
I don't use a hose, its just a thought. If the calcs don't work out with 5m, use 10m, or 3/4" hose.
It'll be a balance between pumping for too long and not getting a tyre to seat. Probably best to have 1.5 tyre's worth of air in your reciever, though. You won't want to pressurise a 2 tyre reciever, when you come to just seat one tyre.
Posted : 10/04/2012 5:54 pm
