cover the brakes.
theres nothing more to it, if youve got the brakes covered, when you feel yourself over tipping, dab the rear, and it brings you back down again.
(then again, i realy dont get why people DONT cover the brakes, loads of pics of "rad dudes" in all the mags with thier mits wrapped around the bars)
you want to be a low torquey gear (around 32:18)
this is speed dependant, but you want to be able to pedal, but be in a gear you would spin out if you pedalled for any more than a few revs
from a gentle cruise, smoothly apply too much pressure to the pedals, at the same time, allow your weight to sink back over the saddle, and keep your head BACK. the temptation is to move your head forward to realign your CG, which will counteract the tip.
there is NO need to pull on the bars, think of it, not as lifting the bars, but pushing the rear wheel under the front wheel.
as the wheel comes up, it will get easier and easier to lift it (as the front wheel moves backwards towards the rear wheel the leverage it has decreases)
and it will get to a point where it is "weightless"
this is because your CG is now OVER the back wheel, and any further and youll be on your way down onto your back.
to ME it feels like, a hard torquey half pedal rev gets it up in the air, then gentle winding gets it to the balance point, and then balance it between the back brake and the pedalling for as long as you can.
magic.
as long as you have your fingers on the brakes, there is no problem 🙂
