What's wrong w...
[Closed] What's wrong with this recipe? Homemade chilli sauce...
[#5982869]
250g red birdseye chillies, roughly chopped
1/2 x 400g can diced tomatoes
1/4 cup white sugar
1/4 cup white wine vinegar
[url= http://www.taste.com.au/recipes/19696/hot+chilli+sauce ]The mix of imperial and metric units seems to indicate that something has been lost in translation somewhere.[/url] Anyway there clearly can't be 250g of chillies to half a tin of tomatoes- that would be suicide. I assumed that it meant 25g of chillies and kept all the rest the same- but it is still insanely hot. So, is it 250g of chillies to 12 cans of tomato? But then there doesn't seem to be enough vinegar or sugar. Hrumph. Can anyone either figure this out or recommend a better recipe?!?
Posted : 22/02/2014 8:51 pm
Just buy some Linghams.
Lovely stuff and no gaff.
Posted : 22/02/2014 8:54 pm
I'd have thought any home made chilli sauce would have a fair old kick tbh.
Posted : 22/02/2014 9:00 pm
No recipe that I've ever followed would give you chilies as a weight. It's always just the number of whole chillies.
One maybe two birds eye chillies will be enough with a half can of tomatoes. Personally would use a normal chilli with half the seeds out, I.e. Cut in half and de-seed one half. Quarter cup white sugar is a helluva lot too. Prob a teaspoon would be enough for that mix. Try allrecipes.com. They allow you to pick imperial or metric and how many servings you want.
Posted : 22/02/2014 10:35 pm
Make the chipotle en adobo that Tommi Myers does in her book. Phenomenal stuff, smoky, hot, sweet and tangy. ****ing tackle.
Posted : 22/02/2014 10:58 pm
Lose the sugar and vinegar, fewer chillis, add cumin, chocolate at the end.
Boom.
Posted : 22/02/2014 11:07 pm
Just go and buy this instead. nothing you make will be nearly as nice...
Posted : 22/02/2014 11:14 pm
 cdoc
I generally use about 20-30 habanero or scotch bonnets to make 2 x 150ml bottles of sauce. It is very hot, but retains a good fruity taste.
Also, I use about half a sweet pepper to bulk it out a bit, rather than tomatoes as they tend to add a bitter edge which is why I suspect there is so much sugar in that recipe. Many seem recommend trying rice vinegar too, as it has a much softer and sweeter flavour than wine vinegar and may help you to reduce the sugar even further.
Posted : 22/02/2014 11:20 pm
It's obviously 250 chillies. Man the chuff up!
Posted : 22/02/2014 11:36 pm
Scotch bonnets, very hot but really fruity as /\ says.
Found a lovely Scotch Bonnet sauce in B and M bargains. 59p
Posted : 22/02/2014 11:39 pm
YoGrant - Member
Don't joke, that's not far off! They weigh about a gram or two each.
Posted : 22/02/2014 11:48 pm
What you've got there seems more like hotsauce like tabasco so to be used in small amounts and kept for a long time (hence the vinegar). If you want something to use more like ketchup, less chilli, less vinegar and it'll work.
I tend to do hot sauce and the recipe is pretty much what you've got there. That said I tend to blend in some fruit (mango or pineapple) and a bit of something to stop it fermenting to take the edge of otherwise it can be inedible at times due to the sharpness and heat.
Posted : 22/02/2014 11:50 pm
coolhandluke - Member
Like sugar do you? Mind you makes an excellent dip for pakora etc. mixed with yoghurt & dried mint.
The shizz:
Posted : 22/02/2014 11:51 pm
Chilli sauce, the recipie sounds about right. If its to hot just use less.
Posted : 22/02/2014 11:56 pm
Mixing sugar with chilli will make it a lot milder.
So those quantities could well be correct.
Posted : 22/02/2014 11:59 pm
I make a chilli jam and use 5 or 6 bird eye chillies to a 390g tin of chopped tomatoes. I use red wine vinegar not white
Posted : 23/02/2014 12:40 am
