- This topic has 73 replies, 48 voices, and was last updated 13 years ago by tomlevell.
What's wrong with Shimano hubs?
BimblerFree Member
Looking for hub options on a new rear wheel build and it occured to me that no one ever recommends Shimano hubs. The usual supects always get a shout; Hope, CK, Dt Swiss etc but the worlds largest bike equipment manufacturer barely merits a mention. An XT hub is less than half the price of a Hope hub and about a sixth of the price of a Dt240.
So why don't people rate Shimano hubs? Just because of the cup and cone thing?
PeterPoddyFree MemberJust because of the cup and cone thing
Yes, basically. People can't be bothered to look after them and reckon they don't last. Personally I think the opposite. C&C hubs cost 50p for a bag of bearings and a dab of grease once or twice a year. A Hope hub can cost £20 a time to replace the bearings, and they don't last that long either IME (Rarely more than a year)
If you do buy C&C hubs, especially Shimano ones, do yourself a favour and open them up before you ever use them, and pack them with the thickest, stickiest grease you can find and adjust them up properly. I've found they generally come with hardly any grease in them and set a bit tight (Or too loose so they come undone!) Doing this and then regular servicing will keep them running just as long as any modern Hope hub.I recently sold a bike with 4 year old Deore hubs that had cones literally as smooth as glass…..
AndyFull Memberhe he, this old one again. I have just serviced a 12 year old XT rear, that hadn't been touched since purchase. Needn't have bothered, grease was still crystal and bearings perfect. Also serviced a 2nd hand M756 front which was a bit grunchy. New cones and balls, perfect again.
So I agree that good quality cup & cone are longlasting if looked after. However I try to make my bikes as maintenance free as possible and so prefer sealed bearings as when they go wrong, you know there is no risk to the hub and so dont need to do any preventative maintenance and can run them till they die.
binnersFull MemberAn XT hub is less than half the price of a Hope hub and about a sixth of the price of a Dt24
There is a very very very good reason for this. They're crap!! A Hope will last for ever.
I had a front Shimano hub pretty much disintegrate on me on a pretty hairy downhill. Which was fun!
samuriFree MemberI'm perfectly happy with most shimano hubs. I have an front XT which has been going about 6 years now, and that was after I bought it off another guy.
Ditto on the grease thing, they always come empty when new, pack a load more in before you ride and they'll be fine.
ElfinsafetyFree MemberThe freehubs can be quite flimsy; I've broken 3 in the last couple of years, and I weigh less than an anorexic gnat. Replacement freehubs are almost as much as a whole new hub. Hope may cost twice as much, but it will last more than twice as long.
donksFree MemberI have always had shimano and never had any issues with their hubs, currently have the M775 hubs and they are champion…havent touched them in over a year of nearly constant riding and they are fine.
fubarFree MemberSo why don't people rate Shimano hubs?
I'd say they are just too 'common' for a lot of folks on here (but work just fine as far as I've experienced and that's without any maintenance)
mikewsmithFree MemberYou have to keep putting balls into them
You have to keep putting grease into themHope hubs last I have XC's from 2004, early pro II's which require little servicing and work well. Bearing cost more but work better
Shiamano doesn't do the Clicky Thing as you freewheel behind somebody slow
anything else?
ziggyFree MemberShimano XTR all the way for me too, smoothest hubs on the planet. Also like the fact that the freehub is near silent. Not a fan of loud freehubs, also don't like the cost of putting new bearings in a Hope. I also like centrelock so that sways it for me.
The comments above about lack of grease should be less true now as Shimano put sleeves in the hub now which during assembly push the grease to the right areas, boring but true fact.
mcmoonterFree MemberI was out on Sunday with guy whose rear Shimano hub failed in a wierd way. They were the latest centre lock XTs. The cones somehow loosened but tightened themselves onto the cones, siezing the wheel solid. He had a long carry out of the hills for fear of trashing it further.
To have serviced it in the field he'd have needed allen keys, a tool to remove the centrelock disc, and cone spanners, assuming he could just adjust it from the non drive side.
Perhaps a one of, but it kind of put me off them. My last experience with XT wasnt too bad, freehub only lasted 18 months mind. Hopes have been near indistructable.
NickScotsFree MemberShimano=value=reliable.
Avoid pressure washing your bike, can wash out grease etc.
Nick
jonbFree MemberI've had plenty fail on me. It was probably my own fault. I tend to fix things as they break rather than do preventative maintenance. Trouble is when you notice something wrong with a shimano hub it's too late. Less of an issue with other manufacturers where you can replace the whole cartridge bearing.
If you do regular maintenance then they last you well.
If you are looking for cheap hubs/wheels then have a look at superstar components offerings.
ElfinsafetyFree Memberalso don't like the cost of putting new bearings in a Hope
What, from about a tenner or less (if you look around and don't buy from a cycle supplier) for a full set? I've got an XC disc rear hub that's 6 years old and perfectly smooth. I've got a 14-year old Hope front hub that's like a buttery butter egg.
XTR? Let me see now, hmm, Chain Reaction….
http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=1161
£125? For just the freehub? And how much is a Hope Pro 2 rear hub, I wonder…
M6TTFFree MemberI keep toying with buying a set of mt65 wheels or paying the extra for pro 2 hoops. I've found it tricky to get cup and cones just right, endless tweaking, which is why the hope system appeals.
NorthwindFull Member"binners – Member
There is a very very very good reason for this. They're crap!! A Hope will last for ever."
There's a grim inevitability about this, someone's going to post it so it might as well be me
JamesDFree MemberXTR hubs here too & great so far.
Plus great value compared to Hope etc – with Olympics and light spokes, I've got a much more affordable 1377g wheelset 🙂
ElfinsafetyFree MemberNorthwind; that could be sorted with a new hub shell. Good chance Hope might replace it for free, too. If that happened with a Shimano hub, it's replace the whole lot.
Ha ha!
NorthwindFull MemberYou're right Elfinsafety, it's a selling point really isn't it.
ElfinsafetyFree MemberWhat, that parts are easily and cheaply replaceable? Yeah, I'd say so. I'm having a rear disc hub totally sorted for about £30, including new axle, bearings and pawls. Therefore, Hope is better value for money over the long term.
Have fun with your Shimano hubs when your bearing surfaces have worn away!
(Just remembered I've got an XTR rear hub somewhere, freehub's knackered. Not worth the cost of a new one, if they actually still made that pattern anyway. So basically it's now utterly useless)
spockFree Memberthe reason people dont buy shimano hubs is that cup and cones are a bugger to get tightened perfectley, the freehubs are slow engaging and just dont last. Also when they do go wrong, say the rear wheel cones tighten on themselves, if your ten miles from home you either have a long walk or you ruin your drop outs.
Sealed bearing hubs are just much more convenient for mountain biking ,less to go wrong, easy to take apart (two allen keys with a superstar hub) to clean and put a little grease on the freehub etc. The freehubs are serviceable, when they need new bearings you just knock them out ,pay a little for some bearing from a local shop and knock them in. And they'll last a few years (some i know lasted 10 years of weekly abuse in a hope hub).
Price isnt really an issue with superstar knocking them out the same price as deore hubs .(the superstar hubs are great by the way)
samuriFree MemberI've just split a Hope XC freehub but haven't got a picture. The entire freehub with bearings and pawls only cost me 23 quid, not bad for about 4 years of riding.
New sealed bearings for a hope hub can be bought for 3 quid from a normal bearing factor.
Both shimano and hope have been good to me.
NorthwindFull Member"Elfinsafety – Member
What, that parts are easily and cheaply replaceable? Yeah, I'd say so."
No, that they break, enabling to show their legendary customer service in replacing a part that shouldn't have failed in the first place. A thought that will no doubt warm my soul if my Pro 2s do ever split in that way. "Easily and cheaply replacable", yes you're right, it's very easy to completely replace a hub body and rebuild a wheel onto it.
Shimano on the other hand tend not to randomly fall in half, which obviously is a big drawback in some people's eyes. But if one did, the entire hub assembly for an XT, complete, costs less than a Hope Pro 2 outer shell alone so "If that happened with a Shimano hub, it's replace the whole lot." fails to impress.
Shimano bearing faces can mostly be knocked out and replaced incidentally, not that my 12 year old Exage hubs have needed that, as they're still on original hubs and cones. Worn bearing faces are a sign of either huge miles or outright neglect, almost always neglect. Whereas hubs that crack through the middle are signs of poor design or execution.
stuartie_cFree MemberMy experience has been mixed with M775 hubs. Front perfect after 3 years and "inspection only" maintenance. Rear, alas, has been a pain in the arse.
It developed play not long after I bought the wheels (new) and has never been right since. I'm quite happy to pull the whole thing to bits and rebuild it with new bearings and grease but the cone lock nuts ALWAYS loosen off and play develops. I've cannabalised a new hub for the internals but the same pattern has developed and now the cups are pitted so the wheel is effectively done since they are factory wheels and it's not possible to get a replacement shell.
Hope hubs on another bike have been absolutely faultless in 4 years and have only had one set of bearings replaced in the rear.
For balance, I'm a big fan of most other Shimano components – mechs, shifters, brakes all brilliant.
spockFree Memberthe real BIG problem with the shimano is the fact their cones can just decide to tighten and you can end up in alot of trouble if your a long way from home
ElfinsafetyFree MemberReally? CRC prices for all that lot are £50.97.
My mistake, adding the cost of 4×6001 2RS bearings brings it to about £40. Still a bargain.
I've got old Shimano hubs that have lasted ages (one original XT M700 front hub on my commuter still going strong after 20 years or more), but more recently, I've been disappointed with Shimano's stuff, and their freehubs definitely seem flimsier. I'd rather buy Hope, through choice, based on experience.
13thfloormonkFull MemberYeah, too many failed freehubs for my liking, from both ends of the Shimano spectrum.
I think its a mix of winter riding (this year anyway) and my fondness for low gears and trying silly steep hills/heavy loads. Either way, its the freehub issue that means I'm going DT next chance I get.
NorthwindFull MemberDT are very good, but so damn expensive, that's what led me to Hope in the end for my second wheels.
TandemJeremyFree MemberMy hopes last years on the bearings. 2 sets of hope wheels, a couple of thousand miles a year on each, one set 6 yrs old only one set of front bearings, other set 4 yrs old one bearing has failed the rest are fine.
I don't open the bearings up to repack them however. I believe they last longer if the seals are left untouched if you buy quality bearings.
My experience of shimano is not good – constant maintenance needed and a couple of hubs that are scrap with pitted cups – plus if / when the freehub failed you are fubared – hopes are rebuildable trailside without tools – i carry a set of pawls on tours.
We did wreck a ratchet ring on the hope on the tandem – repaired FOC by hope. as well as 3 shimano freehubs – wheel scrapped after the 3rd freehub failed
Basically you are not comparing like with like – shimano and hop both have advantages and disadvantages so its about preference
bikewhispererFree MemberA properly adjusted Shimano rear hub will spin much much *very* much smoother than a hope, and the bearings will most probably last longer. Unfortunately they seem to come very badly adjusted from the factory.. Often they're way too tight so that they do tend to fail prematurely. They should be left with a tiny amount of play that the QR takes up.
Cup and cone hubs on suspension frames can also self-loosen due to the torque applied from the brake.. A classic problem with Kona Stinkys etc.
Most people don't do the locknuts up enough either as it's a hassle without an axle vice.The good thing though is that you can get a complete hub for peanuts and rob all the internals (cups included) for less than their separate prices.
Overall, I like them. I'm really not sure why, but I do.
AidanFree MemberI have always bought Hope over the last few years but my most recent wheels have done about 3000 miles and that has killed the bearings in a rear Hope Pro II. Unusually, I can tell you that those 3000 miles involved only 1 day of rain.
I don't think that's terribly impressive and, if I could make the choice again, I probably wouldn't choose Hope. The Pro II bearings seem considerably more prone to wear than XCs were.
But to go back to the original point, I'm too lazy for cup and cone so I'd rather spend a bit more on replacing cartridge bearings every 12-18 months. Stupid, but there you go.
mikewsmithFree MemberHope seem to be replacing the split hubs FOC and no questions.
Buy British
TooTallFree MemberHope seem to be replacing the split hubs FOC and no questions.
companies tend to do that when there are intrinsic failures in products. For all the Shimano-bashing, I've never seen a thread on here showing their hubs splitting.
mikey-simmoFree MemberI've always felt that cup and cone hubs are like rim brakes, the more you use them the less of them you have.
stupotFree MemberI must be doing something wrong when I service my shimano hubs. They always come loose after a short period of time, a real pain to maintain!
Ive had two shimano freehubs fail, whilst out riding. Oh and one hub the outer casing split on the non-drive side. If its still in my shed I can get a photo.
Cartridge bearings all the way for me. Got a 5 year old specialized hub thats still perfect with no service. And my Pro11 have been ok so far…
D0NKFull MemberShimano front hubs are fine, last forever serviceable etc. Rear hubs not so. The freehubs go and they are non-serviceable and cost not much less than a new hub. It used to be that the freehubs lasted quite a long time but the latest XT/XTR ones have bigger axles and smaller bearings and I've had one go after not very many miles at all and so have others on here.
C&C are good if you're into maintenance (and bearings cost pence) but a pain if your not. I've pulled C&C apart and found the grease still perfect after 12months, other times after 6 months theres nowt but rusty gunk in there, and you never know which it'll be till you open them up (once the wheel has play your bearing races are already wrecked IME)
With sealed bearing hubs you can run them into the ground, you don't have to keep an eye on them, completely trash them, then for a few pounds make them like new.
bigyinnFree MemberFreehubs are the weakpoint of shimano hubs for me. Im a bit if a big gear masher and im about 17st, so i go for hope nowadays.
Although i'd argue the point about being able to replace the bearing races on Shimano hubs, cone yes, but never heard of replacing the races.cynic-alFree MemberShmano hubs should not loosen if adjusted and set properly IME.
I'm a happy shimano user, but with the horror stories on the new freehub bodies, if I ever need new hubs they may be hope.
Eh? Nonsense!
The topic ‘What's wrong with Shimano hubs?’ is closed to new replies.
