- This topic has 174 replies, 80 voices, and was last updated 8 years ago by Buzzard.
Whats up with my XT brakes?
Ecky-ThumpFree Member
The oil was black and very viscous, after about 6 months riding. I obviously need to take into account the shelf life of mineral oil
There may be a clue here.
I’ve had black fluid at the lever end on two occasions. Evident when bleeding bottom-up. It seems to coincide with the onset of inconsistent lever feel.
I strongly suspect the cause is deterioration of the seal in the lever.
In use, through the early part of the stroke, the seal passes over the bleed holes that connect the master cylinder and its reservoir. My suspicion is that the seal is suffering a cheese-grater effect when passing over these holes and the black fluid is a result of this.Another symptom is that the system often resists bleeding bottom-up. The free stoke adjuster is wound back but the lever doesn’t naturally return to the very start of its travel. I suspect the seal on the piston is still blocking those transfer ports to the reservoir.
legendFree MemberHow badly will they blow me off?
I’d bet on getting completely ignored
banksFree MemberJust send then back, common & well known problem. Just had an older xt replaced with the brand new one, so fingers crossed.
gelertFree MemberOther way around with me. My SLX seem very good and bleed extremely easy (only the front has needed a top up after 1000 miles) and to be fair I’ve had no trouble at all with them. No inconsistent braking on them.
My XT rear particularly needs the “pull it just to make sure it’s there before you brake properly” thing quite often. The XT rear needs regular mini bleeds to feel right but I’ve not tried the trick of unscrewing the free stroke adjust before bleeding to allow me to overfill slightly and increase the “pressure” later. I’ve even had it bled by my LBS in case it was a home-mechanic-issue and that made no difference.
I used to have it when the pads wore down to a certain point the XTs would become weird feeling and I’d just put new pads in and it would be fine again. I’ve since realised it’s more than that because the SLX brakes just feel loads better under my fingers throughout the pad life.
Been thinking I’d do a proper full bleed on the rear XT really soon as I did a mini bleed and fitted new pads recently and it’s gone a bit rubbish again.
banksFree MemberMy deore brakes were perfect i should add. Really regret selling them.
jemimaFree Memberhhmmm – interesting. My M9020 XTRs did this from new. Got one bleed at the bike shop to no avail. I just kinda got used to it.
What I was wondering at the time was whether it was a mechanical issue as opposed to hydraulic, my reasoning being…
I think these brakes have a Servowave feature? Although no Googling ever gave me any good answers. To my thoughts Servowave means the initial lever pull gives low mechanical advantage and quick pad travel to quickly get to the bite point and then on contact changes to high mechanical advantage for strong braking. The change is due I think to a pin or pivot point shuttling across when the load comes on. So I wondered if the ‘switch’ between modes got stuck sometimes??? My brakes always needed the initial pull which gave long lever travel, then quick release and then on reapplication gave good braking with the lever a bit further from the bar.
Don’t know if there’s anything in that or not. Maybe I’m just getting confused with ancient Shimano cable pull brakes which definitely did this and the mechanism was clear to see:
http://faqload.com/faqs/bicycle-components/brakes/xtr-servo-wave-brake-adjustment
My brakes have never felt like they actually needed a bleed – they are not spongy as if there’s air in the system…
HoratioHufnagelFree MemberMine do this too!
I’ve bled them multiple times, same issue.
Also bled some road hydraulics in the same way and they are fine.
gelertFree MemberI think both SLX and XT have Servowave too.
On the XT rear I tend to have to run the rear leaver further away from the bar than I’d like as that’s the only way it can’t possibly end up pulling to the bar and usually that’s enough leaver throw to have bite where I expect it to be which suggests servo wave is in action. On the SLX I can position the leaver where I want and it’ll always work ok.
I may ask at my LBS when I next go in.
sharkattackFull MemberIf you’re having a problem I suggest you email Madison to inform them of it. I got a reply and apparently they’re not aware of any issues. Which is odd because if you Google it you can find dozens of discussions just like this one.
P-JayFree MemberI’m really getting the arsehole with this now – mine aren’t the M8000 but they’re brand new, multiple bleeds and they’re woefully inconsistent – first pull almost now power, second a bit better, third rock hard – pretty much where you want them – was riding a horribly slippery Caffel at the weekend, had to take evasive action on one section and ride out of a turn and into the trees because I was never going to make it at the speed I was going at, later on I’m fighting a high side when the front locked without warning. I took to pumping them up and then riding with the lightest of brake drag on to hold pressure.
To me it feels like the pads aren’t self-adjusting and want to go back to fully open even when the pads are part-worn, there’s certainly a lot of light between them compared to my Deores which are perfect.
tom.nashFull MemberI am sending this thread to Madison on Facebook and see what they have to say…. I almost had a horrendous crash today as pulled the brakes to stop rapidly and nothing happened… to have to pump the brakes in advance of when I need them is not right!
edward2000Free MemberOP here, i cant believe how common this problem is! I thougt it would be a simple fix! Has anybody actually had this problem and solved it (without buying new Brakes)?
sharkattackFull MemberHas anybody actually had this problem and solved it (without buying new Brakes)?
From Madisons reply to me;
There is no re-build kit available, so it would be a case of purchasing new parts to try and resolve the issue.
In other words, you pays yer money you takes yer chance.
No more Shimano brakes for me.
edward2000Free MemberI brought them 10 months ago from CRC and this Problem has been from new. Warranty job?
sharkattackFull MemberYeah go for it. I left mine too long because I rarely use the DH bike and thought I’d be able to fix them. Bit gutted now as they’re in near mint condition but technically a write off.
rickonFree MemberI love how polarised this thread is to all the Hope vs Shimano, or SRAM Guide vs Shimano.
I’ve had all my sets of Shimanos do this, and lots gone back under warranty. Nothing would make me use them again, total pain to own and disposable.
My Hope e4s never did anything that would possibly injure or kill me, and neither have my Guides.
I’d argue a failure mode that has a good amount of anecdotal evidence, and that is serious enough to injure needs investigation by Shimano.
I’d urge those with the same issue to file a complaint, to ensure its recorded and dealt with.
StevelolFree MemberThis is odd I thought the latest shimano xts ‘just work’ and were the best thing since sliced bread?
banksFree Member2 year warranty btw. Get them returned whilst the weather’s shite.
ir_banditoFree MemberI’ve got 2 pairs of SLX (latest model) and one set was doing this.
Bled them with the Epic Bleed Solutions kit. (as part of the process, when I removed the pads I realised they were all right down)
Post-bleed, they’re rock solid.EBS FTW.
nwmlargeFree MemberI don’t get the random level pull issue but i do get the upside down issue.
If the bike is upside down for a period then the levers will pull to the bar a couple of times.
I need to bleed them properly.
gonzyFree MemberBled them with the Epic Bleed Solutions kit. (as part of the process, when I removed the pads I realised they were all right down)
i agree…i use the Epic bleed kit and never had a problem yet. mates brakes did have a problem but a good couple of bleeds using the Epic kit forced some nasty looking brake fluid out which was then replaced by some genuine shimano mineral oil. they work perfectly now.
again i agree with this….if you have an issue that doesn’t seem to sort itself with a bleed, send them back…that’s what the warranty is there for
if you have XTR kit then its covered by a 3 year warrantyaphex_2kFree MemberMine are fine. Wonder if cold and damp/wet affect them? Dry and warm here. Of course, I’ve just jinxed myself, no doubt.
How do the people who have issues use the Free Stroke (or screw of pointlessness)? Seems to do bugger all for me.
legendFree Memberi agree…i use the Epic bleed kit and never had a problem yet. mates brakes did have a problem but a good couple of bleeds using the Epic kit forced some nasty looking brake fluid out which was then replaced by some genuine shimano mineral oil. they work perfectly now.
I’ll be that guy and disagree. EBS kit in action here, definitely better than the Shimano method but still not great. The fact that it needed “a couple of bleeds” tell you a lot too. Older Shimanos took one 5-10min bleed* and they’d go for years.
Also, does anyone else get a worse bleed when using the yellow piston spacer?
*top down only and half the time you just had to open the bleed nipple and leave it for a while
Garry_LagerFull MemberAlso, does anyone else get a worse bleed when using the yellow piston spacer?
*top down only and half the time you just had to open the bleed nipple and leave it for a while I routinely get a soft brake on a rear slx after a bleed – frustrating, the front is fine. I was thinking I need to experiment without that spacer to see if that’s the problem. Maybe press the pistons out a little bit so the system gets ‘overfilled’.
scotroutesFull MemberOn previous generation Shimano brakes (with no method of adjusting lever travel) I use a thinner, hand-made spacer. It allows a certain amount of “over-fill” to move the bite point out.
Edit: that’s for my own bikes because I like it that way.
cardoFull MemberWatching this thread with interest….
I’ve bled quite a few sets of Shimano brakes for friends and my own, using the Epic kit and whilst all but one set have been fine , one set did keep coming back with “it’s gone spongy again” … Although 3rd time lucky might have got it.
Must admit I don’t use Shimano fluid or the yellow spacer I found the Green bottle opener key ring MBR gave away a couple of years ago fits Shimano and Hope callipers perfectly.gonzyFree MemberAlso, does anyone else get a worse bleed when using the yellow piston spacer?
i use the yellow block for my front zee but i wasnt sent one for my rear slx….so i use about 4 1pence coins wrapped in tape….does the job
i usually bleed form both ends…i first start at the caliper and use the srynge to force the fluid up the brake and out of the lever reservoir and into the big syringe thats screwed into the lever. i tap the caliper, hose and lever to knock out any air bubbles. i then fill the top syringe with fluid and let it drain through the brake from lever to caliper and out though the bleed port valve. again i will tap the lever, hose and caliper to knock out any air. i then repeat this process if needs be until the brake feel and lever movement is right. on my mates i had to do this about 4 times….took about 30 minutes per brake but it was worth it in the end.
gonzyFree Memberdont use the weldtite mineral oil like my mate did….absolutely useless!!
swanny853Full MemberI found this with a set of second hand xts, but have had no problems with deores or slx on mine or the other halfs bikes.
The newer shimano brakes do seem to be a lot more susceptible to pad wear though- my older 775s and 765s could both be into the backing pad and they’d still feel the same (if conditions were bad enough you hadn’t noticed by then) but the newer ones seem to need changing at the stated wear point or they feel off, which is shocking!
duirFree Memberemail Madison to inform them of it. I got a reply and apparently they’re not aware of any issues.
That’s why on a daily bases they replace faulty shimano brakes without question, because they are not aware of any issues.
I have become a high level expert on the tricks of bleeding shimano brakes and even fitted goodridge hoses and bled them vertically, left them overnight and then did mini bleed on the bike. The result was a superb feeling brake with tonnes of power and a consistent lever feel…………….for about 2 rides, then back to the same problem.
I think back to Hope for me because failed but cheap is useless in the middle of the mountains. Would much prefer Hope to produce a powerful 2 pot brake as I always find the 4 piston stuff to be fiddely and less reliable.
JackHammerFull MemberI really want to run the shimano fluid, royal blood and others through a GC-FID and see how different they are in composition. There’s obvious difference in viscosity of the green cyclo stuff and the shimano fluid. Higher viscosity would suggest longer carbon chains and with that a higher boiling point, but Shminano claim that their mineral oil is the highest boiling point, despite it being so fluid.
Read an article once where they had all the boiling points, cant remember where it was though. They had all the brake companies, all talking about mineral oils and dot fluids etc. Why you shouldn’t put royal blood in shimanos and vice versa.
ndthorntonFree Memberdo you have to run the full-retard vented rotor with the V2?
No – you need the V2 rotors but they don’t have to be the vented ones
P-JayFree MemberEcky-Thump – Member
JackHammer
This one?:Well, I’m a fuggin idiot – I’ve been letting the free stroke screw out to bring the bite point out. Should have read the destructions.
Total toss bag.
dirtydogFree MemberThats the one Ecky, was just about to post the link.
There’s a few ‘I know better than Shimano’ types who could do with reading it!
alexhFree MemberI had this on my xt’s for ages. Then, as I was trying out 27.5+, I dropped in wheels with some cheap and nasty discs. Low and behold problem gone. Ice tech discs out and some cheap discs that were marginally thicker installed.
The bike that the ice tech went onto (with xt brakes also) now has a slightly iffy initial pull
JackHammerFull MemberJackHammer
This one?:Yeah that’s it!
Also there’s some stuff on epic bleed solutions website.
The topic ‘Whats up with my XT brakes?’ is closed to new replies.
