Whats this hole for...
[Closed] Whats this hole for?!?
Ah yes I see that.. And the horst link in wikipedia has the same no of bars as the kona.
Anyway, a radial axle path = single pivot as far as I'm concerned, non radial axle path - who knows what to call it..
Posted : 28/11/2011 3:08 pm
leading to a different axle path
indeed, that was never in dispute.
Posted : 28/11/2011 3:13 pm
looky, i made a picture 🙂
(and yes, resultant axle paths, braking etc will be different, just illustrating the misconceptions about 4-bar and faux-bar, they are both 4-bar linkages, but only one is 4-bar suspension)
Posted : 28/11/2011 3:17 pm
amedias good work. I get why its called four bar suspension. What's more important is why single pivot is called single pivot. Because there is only one pivot on the axle path, or one pivot between the wheel and the frame. You can add as many linkages as you like between the other side of the axle and the suspension and call it what you like but if the axle is on a radial arm from the frame then its single pivot. Like the Kona.
Posted : 28/11/2011 3:22 pm
[i]ah, but no, you don't have to have a 'horst' pivot for it to be a 4-bar.
The horst bit only refers to a very specific placement of the pivot.[/i]
Oh, ok. I ride a Yeti anyway, which is better.
Posted : 28/11/2011 3:29 pm
Good lord, I'm starting to have a [i]slight[/i] interest in this now.
So, I get the technical difference. Question is, which is better? I'm guessing proper four bar as it appears it should be defended by a gentlemans honour at all costs, but if it is that much better then why bother with a faux bar design at all? I can't see that it'll cost any more or less....
Whichever is the best colour....
Posted : 28/11/2011 3:31 pm
 5lab
'proper' 4 bar allows for more tuning of the wheel path.
it also eliminates braking forces from the suspension travel eliminating braking squat (which is prevelent on some single pivot bikes). A floating brake arm can remove this problem on a single pivot bike.
single pivot bikes generally have a stiffer back end as there is only one pivot to beef up
Posted : 28/11/2011 3:37 pm
which is better
whichever one you prefer the ride of 😉
I'm a firm believer in there not being a 'best', there are lots of competing designs all with the positives and negatives.
What is best for you is the one that fits your wallet, ride style, maintenance concerns, and sense of aesthetics.
Personally I actually own and have owned faux bar, 4-bar (in FSR and non-FSR variants), lawwill, single pivot and VPP from numerous different manufacturers. I could bore you to tears with the nuances of each one but I would never declare one as 'best'
A lot of MTB suspension designs have come about due to the need to avoid somebody elses patent...
Matt
Posted : 28/11/2011 3:38 pm
Mine was a statement, not a question 😉
Posted : 28/11/2011 3:40 pm
mrjmt
Single pivots as defined by me (including linkage driven single pivots etc) all supposedly suffer from brake induced forces (jack or squat depending on the placement of things). This is either noticeable and destroys your fun, or not noticable, and under certain circumstances some people say it locks the suspension up, although I've ridden SP's all my life and never had any issues. In fact some SP's have such a tiny amount of it that its debatablke if you woudl notice .
A brill explanation of brake induced forces is found [url= http://www.rotorburn.com/forums/showthread.php?35572-quot-Brake-jack-quot-an-explanation. ]here.[/url]
If you read the thing above you will discover that the four bars etc can also get brake jack despite what others would have you believe..
Whether one is better than the other is down to personal choice and marketing bollocks..
Oh and this:-
Several frames have brake arms - my 222 has an Independant Braking System (IBS) arm.
Unfortunately, I'm not 1337 enough to actually notice the difference... but I'm sure someone on STW will pipe up and say there's a huge difference 😉
The black part the caliper is attached to...
Posted : 28/11/2011 3:42 pm
1337 ? que?
Posted : 28/11/2011 3:49 pm
well you have to pay spesh a fiver(or something similar) a bike in patent fees to use a four bar
its a pain for some but for dave weagle its been a godsend!
edit: faux bar was so named by specialized patent department to make their version sound better
how true... Schwinn/Yeti Lawwills in particular are bloody awful for it. However I still ride one on a regular basis and love other aspects of the design, and you get pretty good at anticipating and counteracting the bad bits of most designs after a while.
Posted : 28/11/2011 3:50 pm
whats this hole for?
Its there to [s]provoke[/s] stimulate another lively STW [s]argument[/s] debate
Posted : 28/11/2011 3:51 pm
ha ha sorry, habit instead of writing 'elite' when used in a slightly sarcastic tone. It's a computery thing.
Here's a bit about it..
( http://en.wikipedia.org/wiki/Leet )
Thats OK then as I bought it based on price and colour.
Posted : 28/11/2011 3:55 pm
Posted : 28/11/2011 3:56 pm
cheezo - no arguments here, just grown-up discussion and debate, you must be thinking of the *other* Singletrack, where brand/design loyalty cause threads to escalate into massive flame wars between 'big-hitters' and then everyone starts shouting about helmet wearers....
Posted : 28/11/2011 4:02 pm
 5lab
a mate of mine used to ride an early patriot and it had a lot of brake 'dive' at the rear - the bike would noticably sink down in its travel under heavy braking. the sus still worked though - and having ridden more modern patriots, it seems to be something that doesn't affect the bikes so much any more (maybe due to angles) which could be why orange no longer offer an IBD?
Posted : 28/11/2011 4:13 pm
 flow
Own a Kona by any chance, flow? Getting all defensive?
No I don't actually.
Its just toooo easy 😆
[url= http://webcache.googleusercontent.com/search?q=cache:DFzT-uodcqgJ:www.konabikeworld.com/08_tech_ds.htm+faux+bar+vs+four+bar&cd=5&hl=en&ct=clnk&gl=uk ]Read it and weep [/url]
Posted : 28/11/2011 4:34 pm
that kona article ........
as a konafanboy i agree completely with their PR 😀
buit its sums it up nicely
4-bar = more pedal bob
faux bar = more brake jack
Posted : 28/11/2011 5:20 pm
Well, I spend more time pedalling than braking so..... 😯
Posted : 28/11/2011 5:27 pm
Truth be told, Horst-Link suspension was originally designed for motorcycles. You won't find the system on
any motorcycles today, simply because it doesn't work
Yeh right.
 5lab
not sure why a 4 bar would necesarrily equal more pedal bob? that'd be entirely dependant on the rear wheel path around the sag point surely?
Posted : 28/11/2011 5:40 pm
well in the US you have to pay spesh a fiver(or something similar) a bike in patent fees to use a four bar
FTFY (there are other patent offices who bother with stuff like prior art)
Posted : 28/11/2011 6:05 pm
 flow
This threads gone quiet 😆
Posted : 28/11/2011 6:32 pm
i like hardtails
Posted : 28/11/2011 6:41 pm
Page 2 / 2
