OK, I realise that nobody is going to take this seriously and that’s fair enough. Any differences are probably too small to matter in practice, but it’s still bugging me.
If a certain fraction of crashes are caused by the front wheel getting trapped in some way and a larger wheel is less likely to get trapped then a larger wheel should result in fewer crashes.
But what about the effect of head angle? Is it true that a slacker head angle also makes it less likely that the front wheel will be trapped/stopped by an obstacle? If so, it could be the case that (say) a 67 degree HA with a 26″ wheel is just as resistant to being stopped as a 69 degree 29er. If not, then the 29er is (theoretically) safer and I can shut up about it 🙂
