OW, no love on here for Avid’s. Running centrelines as well. Think the 200 is overkill for the Uk. The drop down Cartworth Rd into Holmfirth is pretty long,steep and over 45mph and I can make my Magic Mary howl like a good un. More than enough power with tons of control. Where are you based? I have a rotor and adaptor you can try.
sorry dave I read it as you hated them 😆 I think they are brilliant brakes tbh
only reason I was wanting to swap, was id seen a rotor cheap and the mount for the 200mm rotor doesn’t use the stupd CPS washers, ive converted my rear tp none CPS using a avid mount, but sadly the front can only use the CPS washer system with a 180mm rotor
there are ways around it using other brands etc, but wanted to use the same mounts, so was going thinking of trying the 203 up front
probably overkill though we do a lot of steep descents I guess (ride peaks etc), and its certainly not flat
