I’ve been toying with sinking a pair of ‘telegraph pole’ type timbers vertically, about 3m apart, then having a metal bar spanning the pair (like a crossbar) About 11ft up..
This will create a structure to have a swing/Olympic ring/Arial hoop hanging from.
I’ll probably get some rings (for fixing) welded into the bar, and either have the bar ‘passing through’ the timbers, or have a fixing plate fitted to the end do it can bolt into place (11 feet up).
Ignoring the fact I’m likely to need about 16 feet of timbers to make the uprights (twice!), would scaffolding pipe be strong enough to span the 3m and have family P swinging from it like some over eager but underachieving cirque du solero wannabees??!!
DrP
