Viewing 40 posts - 1 through 40 (of 55 total)
  • What size front rotor do you run (29er hardtail)
  • hanchurch
    Can’t decide between 180 and 203.
    butlerjamesp
    180mm is fine, 203 is overkill, unless you are running a strong fork like a 34/36/Pike
    whitestone
    I run 180 front /160 rear.
    Yak
    160. I’m only 65kg though and not very endurognarmax
    SirHC
    183 Front (160rear), Hope X2. More than enough stopping power.
    jakd95
    180 front on a rigid 29er, more than enough. The big bike has 185 and that’s plenty too.
    faustus
    180 front/160 rear. Plenty big enough.
    benp1
    180/160 front/rear on my hardtail and rigid bikes (those are my only 2 MTBs)
    belugabob
    160 front and rear – and I weigh 90kg too.
    Good job I’m wide enough to act as an air brake 😉
    NormalMan
    180 front and 160 rear here too.
    drovercycles
    180 front and 160 rear for me too, I’m 90kg, and have never thought I needed bigger rotors.
    BillOddie
    180/160 for me too at 100kg.
    neilwheel
    180/160 more than enough at 80Kg.
    hatter
    180/160 for XC/Trail hardtail, you’re unlikely to have enough traction to use more power anyway.
    203/180 for the full-suss Gnarrpoon, but I am a hefty bugger.
    warns74
    203 / 180 for me
    bigyinn
    203 / 180 for me too, although I need all the help with braking I can get.
    I’d rather be overbraked than underbraked regardless.
    hanchurch
    203 cost the same can you be overbraked?
    chakaping
    180mm unless your brakes are particularly weak and feeble.
    faustus
    I reckon dropping your heels and getting your body low will have a bigger (and better) effect on braking than a bigger rotor. Give more grip and less OTB rotation…
    heavy_rat
    160mm front and back. can’t imagine why you’d need more
    egb81
    183 front and rear
    eshershore
    unovolo
    160at both ends, I’m the wrong side of 13stone.
    oxym0r0n
    180/160 on both of mine HT/Rigid SS
    Stoner
    160mm f&r, 95Kg. SS, fully rigid.
    welshfarmer
    180 fr, 160 rr. FF29 90kg rider. Big mountain descents. XT brakes
    Northwind
    I usually go 203/160. Very little benefit to smaller rotors, as long as you have a decent brake with good modulation, and they give you lots of margin for error in the event of contamination, maintenance ****-ups, and general loss of performance. So I fannied around with different sizes and arrived at this. The weight difference is titchy so having a setup you can use for anything without concern is worth it for me.
    I suppose it’s kind of like a big diesel- the point isn’t so much the maximum power, you very rarely use it, it’s constant easy usability.
    breadcrumb
    180/160, I did have 160 at both ends but felt a little under braked at times.
    203/180 on my 26″, ‘coz that’s what I had.
    Scienceofficer
    North wind+1 to the letter.
    jimw
    183 each end. 90kg
    scotroutes
    160/160 has never not worked for me.
    DanW
    Never needed more than 160 each end here (on XTR brakes)…. Formula R1’s on the other hand… they couldn’t make a disc large enough to compensate for the loss of performance on any grade over 1%! 😀
    bigjim
    180/180 f/r on the xc hardtail, it’s totally fine, 180 is probably overkill for that bike’s usage.
    203/180 on the full suss though, and might go 203 back, I drag the back far too much and got through a rear rotor in the same time as the original oem pair of resin pads on the front, 120 hours or something, me and the bike together are probably about 100kg though.
    cheshirecat
    160/160 on hardtail
    180/180 on full sus
    75kg here. Never felt like I couldn’t lock the wheels.
    hanchurch
    Any pictures?
    mboy
    180/160 on my 29er HT. Also 180/160 on the FS as well right now, but will probably up that to 200/180 in the new year as I did cook the brakes a couple of times this year on it. Just the right side of 13st FWIW.
    metalheart
    203 front and back. Because that’s what they had in stock. Built up a mates with 203 as well (was supposed to 180’s but shop gave me wrong size).
    We’re both pretty happy with the set up. I’d go the same way again.
    [url=https://flic.kr/p/df2WhM]Finished (and post ride)[/url] by Rotpunkt-UK, on Flickr
    hanchurch
    Still leaning towards 203
    Ambrose
    203 at both ends in the Alps in the summer. I used to drag my rear but am not doing it so much now. It’s all about heat dissipation. I’m close to 100 kg but can easily lock both ends here in Wales in the winter using 160mm discs- but in the summer, on the long descents…. give me 203 front and rear.
    Back at home in Wales I use 185 at each end. TBH, a 185 front and 160 rear.
    Using Avid Codes.
    chored
    203 front on both my hardtail and full-suss, but only because I have a 2013 X-Fusion Slant on one of the bikes and that’s the minimum rotor size it will take 🙁
The topic ‘What size front rotor do you run (29er hardtail)’ is closed to new replies.
