What seat clamp?
[Closed] What seat clamp?
[#2669645]
I sold the Hope QR one as I despised it way too much. It's for a 456SS so 29.8/30.0mm needed. Thinking of a Salsa, anything else out there that's cheap and works well? Can be a bolt jobbie, not fussed about the QR.
Posted : 17/04/2011 2:46 pm
salsa are lovely just need to find one in blue and 30.6 for my new frame that doesn't involve having to deal with the cocks that are mark anthony/activesport.co.uk as they are truly awful 🙁
for cheapy cheap then the superstar ones are actually rather good
kcnc and token do some lovely lightweight jobbos that work much better than hope as well
Posted : 17/04/2011 2:58 pm
None of them offers 29.8/30.0mm.
Posted : 17/04/2011 3:25 pm
I personally like salsa ones and they do a 30mm. I have a black one that's 30mm bolt through but in after a QR one in blue.
Posted : 17/04/2011 3:37 pm
I use a 30mm gusset one from crc, was about £6 (bolt up) and hasn't budged yet.
Posted : 17/04/2011 3:39 pm
On One do a selection from £4.99 upwards.
Posted : 17/04/2011 3:44 pm
Who sells Salsa in UK? Charlie The Bikemonger doesn't seem to stock the clamps, I've emailed him already.
Posted : 17/04/2011 3:49 pm
triton cycles
linky
[url= http://www.tritoncycles.co.uk/brands/salsa_cycles.php ]salsa bits at Triton[/url]
Posted : 17/04/2011 3:54 pm
Could somebody collect it from them and send it over to me in Eire? Paypal awaiting 😉
Posted : 17/04/2011 4:01 pm
No need, they're on eBay. Thanks, tazzymtb!
Posted : 17/04/2011 4:16 pm
Salsa QR is ace
Posted : 17/04/2011 5:17 pm
I was going to say salsa but also check out the Ragley one (CRC have them). Nice long lever and a spare plastic bush.
Posted : 17/04/2011 5:55 pm
Have you seen the Ragley in real life? What quality is it really? Salsa is lovely and it matters (I'm a tart, me).
Posted : 17/04/2011 6:01 pm
I've not. If you want tarty then deffo the salsa. Or that other make that costs £35 or something silly.
Posted : 17/04/2011 6:13 pm
I've got the Ragley one - works fine, in fact it will be going on my new 456SS.
chromag, that's it: http://www.chainreactioncycles.com/Models.aspx?ModelID=40622 yikes!
The ragley one looks like it's sold under the Azonic brand too: http://www.chainreactioncycles.com/Models.aspx?ModelID=4584
Posted : 17/04/2011 6:18 pm
I have a superstar one and it one of the best things I've ever bought. Easy to use and tight. I remove my seat to transport my bike so it gets used lots. I highly recommend it. The big paddle is very easy on the fingers too.
Posted : 17/04/2011 6:21 pm
I'm with andyL. As a cheap alternative to an uppy downy post (the original method ) I use my seat qr a lot, and after all the crap (including hope, cotic, santacruz, and many others) the chromag one consistently performs. I have 3 of them for my now three regular bikes.
Posted : 17/04/2011 6:30 pm
SSC don't have a 30mm, no use recommending them. Chromag one is an opening into a new world of expensive bike bits, not sure I should (not saying I won't either).
Posted : 17/04/2011 6:50 pm
you want a good one, get the chromag, the rest are shit in comparison.
Posted : 17/04/2011 7:41 pm
if i have a 27.2mm seattube, what size seat clamp do you need? i think its 31.8mm but the salsa ones seem to be 32mm? is this the correct one?
Posted : 17/04/2011 7:43 pm
The On-One takes a 29.8/30.0mm one despite having a 27.2mm post. Steel as opposed to aluminium.
Posted : 17/04/2011 7:47 pm
What ever you do don't get one with a plastic bush, get one that has a brass bush or shim, these are far superior.They don't squash and deform then go slack.
Out of stock at the moment. The fixed one is in stock for 6.99.
Posted : 17/04/2011 7:48 pm
I had that on-one clamp and whilst the theory is good, that bush squished out of the way really fast and was soon alloy/alloy and grinding like a good un. The chromag bush isnt going anywhere, its just better..
Posted : 17/04/2011 8:06 pm
Cromag....pah..... just for labelwhores with more money than sense 😆
Posted : 17/04/2011 8:09 pm
 mmb
i've got a thomson bolt-up in really good nic as it's only a couple of months old, it's 29.8mm and came off my 456 which was sold recently £10 posted.
Posted : 17/04/2011 8:26 pm
oscillate wildly, 29.8 or 30mm usually for steel frames with 27.2 seatpost, alu frames with 27.2 posts are usually 31.9/32mm clamp. This is cos you have to make/draw the seat tube walls thicker for aluminum than for steel. 0.2mm difference is not much of an issue for a seatclamp but definitely is for the seatpost!
Posted : 17/04/2011 8:34 pm
cheers julian! yeah alu frame so 32mm it is then! lovely stuff!
Posted : 17/04/2011 8:36 pm
