jairaj – Member
RS Revelations RLT??? 20mm axle straight steerer, not sure of the year. 2010 maybe
These are most likely to have the dual air spring, which gives you more options for adjustment.
Set your spring up with equal pressure in +ve and -ve chambers so that you are no longer bottoming out all the time.
Then add up to 15 psi more on the negative spring. This will make the initial stroke of the spring more supple giving you some more small bump compliance.
Also are you bottoming out on just individual hits or successive hits? If successive hits, it could be your rebound damping is too high and the fork is not able to recover quick enough before the next hit and ends up packing down.[/quote]
Yes dual air. It’s not packing down, it’s just the big hits. I’m up past the recommended air pressure as it is, about 170psi IIRC. Not sure if I’ll blow the air seals if I go much higher.
I’m 1.94m tall & 120KG BTW, so not a whippet by any stretch of the imagination. A lot of people I ride with have said I ride smooth, “for a big lad”.
