ir_bandito
[quote]anyway, anodizing is a surface treatment to harden the aluminium and aslong as its polished up (ie remove any scratches), removing it won't affect the material properties.[/quote]
Not correct, no idea where you got that from. RaveyDavey is right, it's not a surface treatment (like paint) but a controlled corrosion process…. and hardening, while it may be a side effect, is not the main aim of anodising(edit/ I take that back having just looked it up, surface hardness is increased, but only in such a way as to increase wear resistance), it's a corrosion resistant aesthetic finish, not a hardening process.
Take care, I would not be attacking aluminium parts with chemicals especially something like a handlebar. As suggested, go to a finisher for advice or leave well alone
but it's clear that
a/ you're doing it on the cheap, and
b/ you've already started
so frankly you're on your own, sorry but I think you already ruined your h-bars.
