I bought a Fabric Accubar on my own advice. I think it’s pretty good. More expensive that swapping out a gauge on an existing track-pump, but has the advantage that you can use it with multiple pumps and it’s just about light enough to carry on the trail. Works great with a Lezyne Alloy Drive and has the advantage of not unscrewing the valve core like the Lezyne connector likes to.
Means you can tweak pressures on the trail and match them to previous settings that work for you, which I’ve found problematic with the squidge test, probably because I lack the ultra-sensitive finger pads of other posters.
It has a a pressure bleed button, which works fine, and, if you attach it to a tyre at a pressure above 40 psi, which is the maximum the gauge measures, it’ll automatically release pressure until it reaches 40psi. You can use it as a stand-alone gauge as well, though obviously if you do that you can only measure and/or reduce pressure rather than increasing it. But hey, you carry a pump as well, right?
Feels reassuringly solid and well made and can be used on both Presra and Schraeder valves. If I was being picky, I’d say that the markings on the gauge face could be clearer between the main 5psi divisions. Seems good for both 650b+ and standard mountain bike tyres, but a bit low – 0 to 40psi – for my cross bike.
Not cheap at about 30 quid, but saves buying a new track pump wth a low pressure range and is more versatile too.
