Viewing 6 posts - 1 through 6 (of 6 total)
  • What is the chain length rule for 1 x10…
  • rockhopper70
    What is the rule for setting chain length. Triple is chain on big & big +2 links, but what about 1×10.
    Ta
    andypandy85
    Assuming it’s a hardtail, same rule and then check it on all cogs.
    barbs
    Check out the piece on Bikeradar front page today. They are saying add 4 links.
    06awjudd
    L = 2 (C) + (F/4 + R/4 + 1)
    L = Chain length in inches. Round the final result to closest whole inch figure.
    C = Chain stay length in inches, measure to closest 1/8”. Use chart below to find decimal measurement.
    F= Number of teeth on largest front chainring.
    R= Number of teeth on largest rear cog.
    ratherbeintobago
    There was a thing on (I think) Bikeradar today suggesting chain round ring & big sprocket plus four links, as this is what SRAM recommend for setting up XX1.
    Edit: not fast enough…
    Mackem
    I just ran the chain over the biggest sprocket , over the chain ring through the mech and pulled the ends together until I thought the mech was stretched to it’s limit, backed it off to give one link breathing space and that seems to have worked fine.
The topic ‘What is the chain length rule for 1 x10…’ is closed to new replies.
