When you stop pedalling over bumpy ground, the intertial loading on the chain may cause dynamic excitations and spacial misalignment. This, coupled with the isotropic materials used in the funicular chain-sprocket can produce undesirable effects in the presence of silica crystals and large masses of stone. I suggest that the inherent weaknesses in this design should be mitigated by combining the loading characteristics of the handicapped mainstay assembly with the self-meshing properties of the flux-energy alignment array. For even better performance use a hydrocarbon based (NOT water based solvent!!!) lube.
If all else fails, find your local machine shop and get them to machine you a snub-dongle, which will be useful in maintaining the haphazard hysteresis due the uneven wave-function of the loading and also prevent sudden and catastrophic loss of pedal-resistance.
TL:DR: It could be a child’s face next time.
