What Goodridge Kit ...
[Closed] What Goodridge Kit for Avid Juicy 3s...?
[#1190257]
Anyone know which Goodridge connector kit works for Avid Juicy 3s? I read somewhere that the Goodridge Connector Kit 104 for Shimano M525 or Magura HS33 also works for Juicy 3s - is this right?
Posted : 06/01/2010 3:54 pm
I assume you can fit original Juicy inserts into the goodridge hose as it is just the threaded barb into the pipe, olive and compression nut [which you put on first !!]
If hose is same size as your avid I am not sure you need a kit. Merlin sell required bits-about £5 for everything - I would assume CRC do as well.
Posted : 06/01/2010 4:06 pm
Thanks Junkyard but I'm looking to replace all the connectors as they have become badly corroded - I figure Goodridge stainless steel ones should last and I also have some spare Goodridge hose lying about. the Goodridge system also doesn't use olives from memeory.
Posted : 06/01/2010 4:18 pm
