My Specialized Deviant full-facer was in the car a few weeks ago when it got hot… very hot. It was covered up and the sun wasn't on it directly, but the internal car temp was very high and when I used it a few days later, I've found that the outer shell has come unstuck from the thick foam inner shell.
The inner shell is currently being held in place by edging strips in the liner (front, back and sides) and the fact that the outer/inner shells are a good fit together. There's only a small amount of movement, so I haven't been unduly worried that its not safe but it is annoying to have it rattling so much. Upon closer inspection through the vents, I can see several large blobs of glue on the inner shell which must have been softened sufficiently to lose grip on the outer shell.
So, is it unsafe and a write-off? Or what glue should I be using to fix it? Cheers.
