I'm having no luck tracking down a squeak that appears to be coming from the rear of my bike (although I appreciate that pointing noises on a bike can be difficult). The squeak has transfered to a new frame along with the old kit (the bottom bracket is new).
The squeak isn't particularly loud or alarming, but I'd like to get it sorted. It's intermitted but seems to occur at relatively low cadences (possibly when pushing down on the non-driveside pedal). Pushing harder on the pedals has the odd effect of appearing to make it vanish.
To date I've tightened the non-driveside crank, removed the non-driveside pedal and cleaned and re-greased the threads, removed the cassette and re-greased the freehub splines, checked for loose spokes and removed the spacers on the hub and greased under them – all with no success.
So, what next, could it be a bent axle or the bearings on the way out?
