Educate me about concrete, i'm after some cheap concrete to attach a ground anchor to.
i guess not all concrete is the same so want to know what people usually use or will anything do?
any concrete tips welcome
1 part Cement, 2.5 parts Sand, 3.5 parts Aggregate (20mm stone) don't mix it to wet
What are you trying to anchor back? How long is the anchor, what dia (assuming circular) is the rod and what size hole?
Buy post mix and just add water.
Lowey speaks the truth.
I'm possibly over thinking this. Do you mean a steel plate anchor for your bike?
yea a steel type anchor for the bike so bolt or set in concrete
so would post mix concrete do the job?
Post mix will be fine! However what you fitting it to?? Is it into an existing floor etc where youve dug a hole out??
You must log in to post.
