A friend's RST Gila fork (100mm, 30mm stanchions, about 2500g) has eventually died, so he needs a replacement. As per the above, it should be 100mm travel, V-brake compatible, must cost an absolute maximum of £230, and ideally should weigh less than the existing fork. Oh yes, a fork which is relatively 'fit and forget' would be helpful as I doubt it will be serviced very regularly. I don't think he needs U-Turn or similar at this stage.
I've seen Rockshox Dart 3s at EUR101 plus P&P from Germany, or £130 ish in the UK. As a result of their 28mm stanchions, will these feel really flexy compared to the 30mm Gila ones?
I've also seen a number of Rockshox Tora SLs at £130 to £160 ish, but it is not clear if they have the V-brake lowers or disc only lowers.
Then there is the Magura Odur at around £230. Is it worth paying the premium for this over the others above?
Is it worth looking at Marzocchi, or have they not quite sorted out the quality control issues with the 2009 range?
What would STWers recommend, and are there any forks I have not considered which would be good?
Thanks in advance for any help provided….
