Viewing 12 posts - 1 through 12 (of 12 total)
  • Wet arses on wooden benches – Oil or Varnish the bench?
  • WorldClassAccident
    Just finishing some seating for the man cave and need to decide on the finish for the top of a wooden bench / seating box. It will be a series of planks nailed into position.
    What is most resilient against the soggy shorts of the wet arses who will be sitting on it?
    I was thinking possibly Yacht varnish but I would have to buy that and I have some linseed oil sat in the garage already.
    The planks have a nice grain effect so showing / enhancing that would be nice too.
    bigh
    If it’s staying indoors, consider wax. Linseed oil will take ages to dry if it’s raw. Boiled linseed oil would however be okay
    WorldClassAccident
    T’is boiled linseed oil. I just wasn’t sure how water / dirt proof it would be
    nixie
    A week ago this was just idle talk as I stole your tools and now you’ve built it 😀
    sharkbait
    A good varnish will show off the grain nicely – and will be very very resistant to water.
    andysredmini
    I would use osmo. The external one. Amazing stuff and really easy to get a professional finish. Easy to touch up later too as you can apply on top of the existing.
    Stoner
    danish oil builds up well and is waterproof/beads water.
    willard
    Someone let him loose with tools on his own???
    WCA, do you still have all your fingers?
    drliamski
    Oil will be better in the long run as you can top it up as needed without having to sand down again
    project
    Danish oil, doesnt scratch, like varnish, can apply more as it wears amnd is waterproof and child safe, we used to use it on wooden toys.
    WorldClassAccident
    Of course not. Did you really need to ask?
    Not quite. One wall finished. Seating finished, well first coat of varnish applied, 2 more tomorrow
    Still need to do the second wall and bar / stereo storage
    WorldClassAccident
    Oil will be better
    Damn, both posted while I was in the garage applying varnish. Oh well, too late now
The topic ‘Wet arses on wooden benches – Oil or Varnish the bench?’ is closed to new replies.
