WCA Shed Thread
[Closed] WCA Shed Thread
[#6500924]
Here is a thread to record my plans, progress and injuries though the journey of building a new shed.
Today is day 1 so not much to show yet but here is the plan
Here is the location, butting up against the back of the garage.
Clearly I will need to move the wood store and other clutter but I have made a start on the plants
The slabs mark out the edges of the planned shed.
It looks like the crab apple will need to move too.
I will try to update when stuff happens. Hopefully today I will move the tree and dig the holes for the supporting pillars.
Posted : 22/09/2014 10:44 am
Sex pond?
Posted : 22/09/2014 10:53 am
Swing palace?
If it is, you need more pampass grass.
Posted : 22/09/2014 11:00 am
Good luck with the build will keep following the thread!
Posted : 22/09/2014 11:15 am
I'm sure this has been posted before, but anyway:
http://www.thedailymash.co.uk/?p=66204&print=1
Posted : 22/09/2014 11:35 am
Posted : 22/09/2014 12:12 pm
Well after working most of the day yesterday on it apart from breaks for the dentist and hydrotherapy I appear to have made very little progress.
Before
After
The two compost bins have been emptied and spread across the flowerbeds, the wood shed has been dismantled and partly moved into the garage (how come there is more wood than I started with?) and I have moved the little tree from here
to here
Posted : 23/09/2014 9:18 am
Nice drill holder 🙂
Posted : 23/09/2014 10:44 am
I put a bit of a spurt on this morning.
Wood moved, wood shed demolished, edges strung out and first few footing holes dug.
Posted : 23/09/2014 11:38 am
Where did you get your info from for the structure WCA. I'm thinking of replacing our current shed and really fancy the idea of building it myself. I'm reasonably handy and could use the old shed as a template to go on.
Are you building the sides then bolting together or putting up a frame then cladding?
Posted : 23/09/2014 12:15 pm
[i]Are you building the sides then bolting together or putting up a frame then cladding? [/i]
Based on past history, I suspect it's whichever approach involves the most peril and opportunity for disaster.
Posted : 23/09/2014 12:17 pm
Is that a sliding door on the left?
Looking forward to seeing how that goes as it's a nice touch.
Posted : 23/09/2014 12:18 pm
My design would be a similar shape with a sloping rather than apex roof but I'm looking at bifold doors of some sort.
Posted : 23/09/2014 12:22 pm
I'm hoping no ladders will be involved in this build....
Posted : 23/09/2014 1:00 pm
WCA can you confirm for safety sake that you will not be using:
Ladders
Drills
Saws - powered or hand
Hammers
Screwdrivers
Nails or screws
Anything that involves been lifted above ground level
Posted : 23/09/2014 1:18 pm
Last time it was his ankle. Shall we start a sweepstake on what he'll break this time? Electricity and water are involved with this build, so I reckon some sort of comedy electro-drowning after coming through the roof.
Posted : 23/09/2014 1:38 pm
It is a sliding door on the left as a Bi-fold is expensive for a 3.6m length.
Shed structure is my own design based on internet info for the floor and roof beam/joist spacing. All measurements are 1.2, 2.4, 3.6 or 4.8 to make it easy to use standard timber lengths.
Floor will go down with 2.4 verticals at the corners and half way along the long side. The panel frames will then be screwed in and then clad the whole lot with red cedar tongue and groove on the outside. Probably plasterboard for most the interior with wood for the sauna interior.
Posted : 23/09/2014 3:00 pm
[i]Last time it was his ankle. Shall we start a sweepstake on what he'll break this time? [/i]
The ankle wasn't the last one. Do you really think I have been two years without injury, even allowing for the 6 months I was forced to stay in bed. Fool!
Posted : 23/09/2014 3:01 pm
Work has stopped for the day.
Who won the sweepstake?
Posted : 23/09/2014 4:16 pm
Posted : 23/09/2014 4:39 pm
My son did that for real when he was about 7.
The South African doctor who treated him at A&E clearly misheard and nearly fell off his chair when cheerfully told "I put a garden fork through my welly" 😉
Posted : 23/09/2014 4:43 pm
Possibly a reconstruction shot but my hands weren't shaking this time
Posted : 23/09/2014 6:57 pm
I did that when I was a kid. Literally pinned my foot to the grass. Mother wasn't impressed. Worst bit was when she had to pull the fork out!
Posted : 23/09/2014 7:07 pm
you are, with out a doubt, the most accurately named forum member... Ever! i salute you and your local a&e.... 😆
Posted : 23/09/2014 7:31 pm
At least I get new trainers 😉
Posted : 23/09/2014 8:12 pm
Rather conveniently, Southampton General A&E is within falling distance of Chez Nick.
Posted : 23/09/2014 8:53 pm
May I suggest.... [url= http://www.safetybootsuk.co.uk/dr-martens-15184201-rigger-boots-brown-leather-rigger-work-boot-with-steel-midsole-p-90960.html ]some of these...[/url] and possibly a hard hat, body armour, someone else to do the work???? 😆
Posted : 23/09/2014 9:07 pm
 P20
Can we have a greatest hits of your escapades?
Was it yourself who created the led lights with the wood housing?
Posted : 23/09/2014 9:41 pm
I'm looking to build something similar.
What did you use to design it?
Is the floor just plywood, and is there a wall of plywood against the house?
Posted : 23/09/2014 9:56 pm
subbed
Posted : 23/09/2014 10:01 pm
[i]Can we have a greatest hits of your escapades?
Was it yourself who created the led lights with the wood housing?[/i]
Check the back issues or=f STW magazine for 'The hard way to become a poet' and that gives about 1/3 or the stuff before the ankle, the first time I did the ankle. I can't list all injuries because it will overload the www apparently. 😉
Google Sketchup for the pictures and internet building advice for the details. 450 for floor joists, 400 for walls needing plasterboard, joist and rafter size tables are available
Posted : 23/09/2014 10:22 pm
hmmm its been 20 hours since his last post... should we be worried??? 😯
Posted : 24/09/2014 6:29 pm
He's probably nailed his last post to his arm or something.
Posted : 24/09/2014 6:32 pm
😆 all I keep seeing is the mental image of the built shed with a pair of feet sticking out from one end and an arm and hand, withraised thumb saluting, from one side... 🙂
(wca.. I don't want to see it, it's only in my mind... Please don't recreate in real life)
Posted : 24/09/2014 6:47 pm
Sorry to scare you, I am still mostly alive
Footings dug and concrete filled. Here is a partway through photo.
Posted : 25/09/2014 9:10 am
Lawn needs some TLC...
Posted : 25/09/2014 11:47 am
Looks like its scalped too much, lawn mower height setting needs raising 😀
Posted : 25/09/2014 9:37 pm
Updates man! We need updates!
Have you employed a well recomended tradesman who'll later turn out to be completely inept for us to critique?
Posted : 27/09/2014 10:29 pm
While we are waiting here's my shed thread. Our small shed was really tatty and taking up too much room.
So the plan was to move it behind the big shed. There is a wall behind big shed so I had to remove 50cm square out of one corner as well. I fully expected to muck it up so was reluctant to spend any money on it at all. The light coloured sides are excess wood flooring.
Really surprised that it worked as I'm not to clever at this kind of stuff.
Posted : 27/09/2014 10:43 pm
Okay - I was busy with work towards the end of the week so no shed progress other than ordering some timber which arrived yesterday morning
I carried that lot down to the garage and then nipped down to the builders merchent to get some concrete blocks to level up the base.
Building the pillars to level up the base took ages as I needed all of the towers to be exactly level. My ankle suffered somewhat walking around on the slope.
I am hoping today to get some of that timber in place so there may be a photo later of the base framework. Watch this space
Posted : 28/09/2014 9:25 am
How far apart are the pillars?
Posted : 28/09/2014 9:56 am
Well eight hours of hard work and about 4 hours of progress.
It took me 4 hours to get the first timber bolted to the garage. It is a bit hard to see but there are ten expanding wall bolts holding the timber to the wall.
What are the chances of drilling tem holes through the timber and then the matching ten bigger holes it the wall and all of the holes, bolts and expanding bits lining up perfectly?
Slim. Four long, sweaty and sweary hours it took!
Fortunately things speeded up a bit after that. Once we were happy that all the corners were square and everything was level I just had to fix the joists. Doubles at the tub end of the shed in case people get jiggy in the tub
Bang in the noggins and we are done fore the day. All that in 'just' eight hours.
Middle row of noggins look a b it pissed because I had left some screw heads sticking out when fixing the joists and was too tired to force them in. It is structurally fine and no-one will see it
I stuck some extra little legs under the tub area in case fat people t=start getting jiggy
Now I wait until Thursday when the under floor insulation arrives and then I can stick the 25mm ply flooring down. No photos but 6 sheets of 1200x2400 were also oiled today. Damned heavy to move into the garage.
Sparky due sometime to upgrade the old fuse box in the garage and fit me a 32 amp feed ready for the tub which will need craning over the top of the garage. Then I will start with the walls and roof.
Off for a beer and a bath now.
Posted : 28/09/2014 5:58 pm
So how much of the garden will be left after the build, looks massive on the pics, jealous 😀
no dpm and hard core under the base?
Posted : 28/09/2014 8:34 pm
DPM under all of the legs and between the pillars and the timber.
Shed is 3.6x4.8 so about 1/8 of the lower garden. It was pretty much dead space as it was in shade behind the garage. The lawn and flowerbeds all remain in tact and the patio and upper garden are untouched.
Posted : 28/09/2014 9:02 pm
Posted : 28/09/2014 9:52 pm
Page 1 / 4
