have is that the Q factor is a little big.
I think they’ve reduced it a bit, but this was bad with the old wattbike. I see the cranks are 170 too, not sure if you can change this on the Atom or if you’re stuck with that.
I can’t find much on how it actually works. It sounds like it works more like the Neo (with the virtual flywheel – which would be a very good thing) than a Kickr, but there’s next to no detail on the wattbike site on that. Forget that, still looks like an old fixed flywheel with motor controlled resistance, so more like a Kickr or a Flux. Bit of a shame.
