Having trouble with the Virgin Media Superhub not providing wireless access to the whole bungalow. Outside of the room the hub is in, access is very poor/non-existent.
At first we thought it may be a faulty piece of hardware. We got Virgin to send a new one out but there was no difference. We then had the hub moved more centrally in the bungalow. Again outside of this room acccess is very poor/non-existent.
The Virgin media technician said to try changing the channel the hub operates on to different values (default was 11) by going into the hub using the IP address printed on it. Still no joy.
He said if that did not work then configure the superhub to operate as a modem only and buy a separate wireless router connecting with an ethernet cable. We have not tried this yet but after popping into Maplins and speaking to the guys there they have some powerline adapter things that use the mains as a network and create a second wireless hotspot wherever you put the second plug in adapter. I’m thinking this may be better than the technicians advice. Both options look to cost about £50.
Does anyone have any experience of doing either of these options, or have any other helpful advice?
